Need New battery
Old Feb 17, 2011 | 09:56 PM
jeffandjess4806's Avatar
Default Need New battery
I need a new battery....what are some good ones? for a 92 d250
Old Feb 17, 2011 | 10:23 PM
crazy clem's Avatar
have had good luck with interstate in truck and hot rod/ race car
Old Feb 18, 2011 | 02:42 AM
Mike337's Avatar
After finding this write up I went with Kirkland (Costco), $65.00 for 975 cca, if it dies within 3 years I get a new one free. It's been fine since Nov/10.
"The Basics" Most auto batteries are made by just three manufacturers, Delphi, Exide, and Johnson Controls Industries. Each makes batteries sold under several different brand names. Delphi makes ACDelco and some EverStart (Wal-Mart) models. Exide makes Champion, Exide, Napa, and some EverStart batteries. Johnson Controls makes Diehard (Sears), Duralast (AutoZone), Interstate, Kirkland (Costco), Motorcraft (Ford), and some EverStarts.
Service centers such as Firestone, Goodyear, Pep Boys, and Sears tend to have a large, fresh inventory and relatively low prices. They also handle installation. Stores such as Kmart, Target, Trak Auto, and Wal-Mart may have the lowest prices, but not all of them can install a battery for you. Installing a battery yourself is not technically difficult, but it can be cumbersome, and you have to dispose of the old battery properly. Service stations and tune-up shops sell batteries as well, and they offer convenient and comprehensive service, but their selection tends to be limited and their stock may not be fresh. For cars and trucks still under warranty, a franchised dealer is your first choice, particularly if the vehicle warranty covers the battery. For older vehicles, though, a dealership is probably the last resort—it's the most expensive service venue. The two most crucial factors in choosing a battery are its "group size" and "cold-cranking amps," or CCA.
Group Size. A group size defines the battery's outside dimensions and the placement of the terminals on them. For instance, group size 75 fits mainly General Motorscars. Size 65 applies to most large Ford, Lincoln, and Mercury products. Newer Hondas, Nissans, and Toyotas use size 35. Most Chryslers use 34. You'll also see combinations like 34/78, which has two sets of terminals and will fit either Chryslers or some GM models. Choose the group size recommended by your car's manufacturer. (Reference guides at battery retailers can tell you which group size your car needs.) The wrong size might not fit securely.
Cold-cranking amps. CCA is a measure of a battery's ability to start a car in cold weather, when thickened engine oil and slowed chemical reactions make starting hardest. CCAs denote how much current the battery can deliver to the starter at 0° F. Don't confuse CCA with CA, which stands for cranking amps. That's a measure taken at 32° instead of 0° and is typically much higher than the CCA rating.
Key considerations
Reserve capacity is another important measure of battery quality. It indicates how many minutes your car might run using the battery alone, should the car's alternator fail. You may have to check product literature rather than the battery's labeling to find the reserve capacity.
Buy a fresh battery—one manufactured less than six months earlier. Batteries are stamped with a date code, either on the battery's case or an attached label. The vital information is usually in the first two characters—a letter and a digit. Most codes start with the letter indicating the month: A for January, B for February, and so on. The digit denotes the year: 0 for 2000, say. For example, B3 stands for February 2003.
Warranties. Like CA ratings, battery warranties can sound better than they are. You'll see two numbers: one for the total warranty period and one for the free-replacement period (usually three months to three years). The free-replacement period is key. If the old battery fails after this period expires, you get only a prorated credit toward a new battery.
How to choose
Performance differences. Our tests of batteries regularly show wide variations between and within brands. See below for details on how to obtain Ratings and additional battery information.
What you can do. Check the battery group size and CCA for your vehicle. Not every brand comes in every CCA level. To get the brand you want, you may need to go a bit above your car's CCA requirements.
Steer clear of batteries with a CCA rating below the one specified for your vehicle, as well as those rated 200 amps or more higher than the specified rating. It's a waste of money to go too high. Buy a battery with the longest reserve capacity you can find. If it's not printed on the battery (and it usually isn't), ask store personnel or check product literature. Should your car's charging system fail, a longer capacity can make the difference between driving to safety and getting stuck.
Old Feb 18, 2011 | 04:05 AM
cumminsblazer's Avatar
Wow this is a good write up
Old Feb 18, 2011 | 08:35 AM
white93's Avatar
I had good luck with the 1150cca interstate until I took it out and used it in the tractor. Currently Im running a 875cca red top optima, The way I see it is since it only takes like one revolution to start there isn't much need for a big battery.
Old Feb 18, 2011 | 08:44 AM
RAW's Avatar
RAW
Since the theft recovery of my truck, I have been having a real bugger of a time in the cold starting mine (-10F). The insurance company replaced my frozen dead 1050CCA batteries with a couple Mopar 750CCA's. I have nothing good to say about Mopar batteries. I'll be putting a big old 4D batt in the box, with a solenoid to isolate it when the key is off.
Old Feb 18, 2011 | 12:26 PM
justanother92's Avatar
I have always had good luck with any interstate battery. Im running group 36 right now and it does hesitate even at -15 we had in january.
Old Feb 18, 2011 | 03:28 PM
Mike337's Avatar
I looked at Interstate, but for the price I figured I could put 2 in the tray sideways, wired together and get a 3 year no questions asked replacement....we had a few mornings at about 5-8 degrees this winter and I had no problems.
Old Feb 18, 2011 | 03:37 PM
Smarty=Cummins's Avatar
We go with John Deere Batteries. They work good for us they last for at least 6 years or more and never have to worry about it not starting in the coldest winters.
Old Feb 18, 2011 | 04:16 PM
RAW's Avatar
RAW
Deere batteries are pretty darn good. I've been working for Deere for 7.5 years, and not too many batteries get changed. Operator neglect is a different story.
