1999 Dodge 2500 no altenator charge
Old Feb 17, 2011 | 07:43 PM
wmorrispilot's Avatar
Default 1999 Dodge 2500 no altenator charge
Ok I know I have seen one do this before but can not remember what caused it and was wondering if anyone else has had this. 1999 Dodge 2500 altenator does not charge on the vehicle but test good on the bench.... I think it is in the pcm but can not remember ... thanks for your help Wayne
Old Feb 17, 2011 | 07:55 PM
turbostang7's Avatar
the pcm is what tells it to charge, i had one that didn't charge on the truck, and on the local auto parts store tester it passed everytime. i gambled and bought a new one and it fixed it. charges fine now. but im not saying this is your situation.
Old Feb 17, 2011 | 11:02 PM
Tylers99Cummins's Avatar
mine did the same thing, bought a new one yesterday from napa and i haven had a problem yet, it charges fine
Old Feb 19, 2011 | 05:52 PM
banditsdiesel's Avatar
something you might also want to check the dodge alts are really bad about the signal wire plug getting loose of not making a good connection if you move the plug around and it starts to charge the clean it and check the contacts in it.
Old Feb 19, 2011 | 06:00 PM
mysterync's Avatar
#1 cause in our shop is a bad PCM ground. There should be a ground cable from the side of the PCM to the body, clean both ends of the cable and a bit of paint off the body and 90% of the time you'll be fixed up ready to roll!
PS this is a very good cause of a no fault test on a tester. Load testing will sometimes cause pcm to properly regulate voltage. Just a thought.
Old Feb 22, 2011 | 07:15 AM
Rooster24v's Avatar
1st check your your FUSEABLE LINK located in the fuse box under the hood, i thought my alt was bad turned out it the link was burned out. put a new one in and walla! now i keep a spare in my truck.. check that first!!!!
Old Feb 22, 2011 | 08:39 AM
RAW's Avatar
RAW
Wowza! Isn't that fuse 140 AMP? You alternator must have spiked or something!
Old Feb 22, 2011 | 08:47 AM
mysterync's Avatar
No doubt, if that's bad there is most likely other issues unless it was damaged by vibrations or something of that nature. That's not a very common failure.
DirtyDiesel58
Jun 7, 2015 11:50 PM
Dec 29, 2014 10:20 AM
Nov 24, 2014 08:20 AM
veggyoilkid
Tire, Wheel & Suspension
Nov 5, 2014 01:34 PM
Oct 24, 2014 02:50 PM
