91 problems with starting
Iv got a 91 non turbo that will not start at all unless pull started need help asap I know starting fluid is bad but even after a good shot after the glow plugs cycle won't sputter or nothing. But if you pull it, it fires right up
first check bateries, then its usualy glow plugs, but it can be the controller or the temp sender in back of block ther is also a cylinoid on manifold that sends power to glow plugs check to se if your geting power to glow plugs when light comes on. i like to pull glow plugs and test with a batery. 6.9s are notoriouse for bad glow plugs if they dont work no start.and dont use either!
It's spinning fast enough I know that. I have 2 1989s 2 1994s a 1993 and a 1996 all ford diesel except for my dodge. I just noticed some diesel leaking out of the return lines overnight would that do it? Thanks
GasItOut
35
Jul 22, 2015 01:11 PM
hurriedcoyte
Jun 19, 2015 06:26 AM
JRB1960
Dec 1, 2014 09:24 PM
