1992 d250 Front end sagging
I have a 92d250 and the front sets 2" lower then the rear...what can i do to raise it up? Do any of the spring booster things work? do t hey make a coil spring lift spacer for my truck?
Most trucks came like that from the factory. You could do add a leafs but it would make it ride even stiffer. A two inch leveling kit would make it ride the same, and look pretty mean
Again they came like that from the factory! its 2 inch higher in the rear cause these are work trucks and your expected to have a heavy load in the back. So when your load is in the back it evens the truck out and doesn't have that sagging look.
7226S is the part # for Severe Duty Springs you can have special ordered from any parts store or find online for about $150plus bucks or so, I just put some on mine (92D250) to get the clearance for the 285/70/R17 Nitto Dune's I just put on, no rubbing looks awesome, some have said ride quality suffers but in my opinion it was improved on my truck
