anyone installed a recirculating block heater?
Old Feb 16, 2011 | 09:23 PM
jpfiero's Avatar
Default anyone installed a recirculating block heater?
The factory block heater quit on my truck, so I installed a tank style recirculating coolant heater. I installed it inline with one of the heater hoses, but it's not working at all. Has anyone installed one of these? Where did you hook up to? I would like to hookup to the head near the back but I can't find a good place any suggestions? I think I shouldn't have any problems drawing coolant near the lower rad hose, but I'm not sure where to hook up the return line.
Thanks for any help
Old Feb 16, 2011 | 09:52 PM
RAW's Avatar
RAW
I would hook up the return line as far back on the head as you can. A fitting behind the fitting for the heater core hose would work. I have my Espar, a diesel fueled coolant heater, plumber in series with my heater core and it works really well. It's odd that yours isn't working. Does it not pump, make heat, or a combination?
Old Feb 17, 2011 | 08:31 AM
jpfiero's Avatar
My return runs through the heater core and then enters the head right behind the thermostat, I think the thermostat is opening and causing all the warm water to flow through the rad. It will heat up the hose to the head but then a couple hours later the hose is cold again.
Is there a fitting I can use near the rear of the head? I don't remember seeing one back there, but I guess I'll have to get under the hood and search, not fun since it's -30c (-22f) right now
ramrunner01
Feb 25, 2015 11:14 PM
chris_fininzio
Jan 7, 2015 03:19 PM
94_12v
Jan 4, 2015 10:37 PM
bikernut
Audio Equipment/Electrical
Dec 18, 2014 03:30 AM
Low_Life_Style
16
Nov 29, 2014 06:28 PM
