crazy exhaust sound
Old Feb 16, 2011 | 06:40 PM
01dowork's Avatar
Default crazy exhaust sound
guys i have got the most annoying exhaust vibration sound in the world. my truck has a 4 inch silver line exhaust. i just put a muffler delete pipe on it. before the delete pipe it would always make a vibration sound when i put the truck in gear and it changed the idle. when i put the delete pipe on i had to cut the welds on the original exhaust hangers. instead of rewelding the original one back on i put a hanger from auto zone on it ang anchored it to one of my bed rails on the bottom. when i did that it raised the exhaust maybe 3/8 of an inch and the sound quit. the damn screw on the hanger came out yesterday and the sound is back. any help? any ideas on what to do? o ya and i put a new screw in and it still does it Thanks i appreciate any ideas
Old Feb 16, 2011 | 08:20 PM
banditsdiesel's Avatar
check the system font to back you most likely have a spot rubbing somewhere. and when you moved it, you got it off where it was hitting at.
Old Feb 17, 2011 | 07:55 AM
biged681985's Avatar
most times it will be rubbing on the tranny cross member
Old Feb 26, 2011 | 10:17 PM
JSPulliam21's Avatar
Or at the down pipe up next to the bell housing.
Old Feb 26, 2011 | 10:45 PM
mysterync's Avatar
Might check the transmission mounts and motor mount while someone pulls it in gear. You'll find the vibrations . Just make sure the parking brake is set and wheels are chocked. I know it sounds stupid but anything can happen and it only takes one mistake. For instance a guy we have worked with for years, that's been around big jobs and was well trained in job site safety was killed by a truck moving less than 2 mph . It's sad but it happens. Take every precaution! Maymead Accident Proves Fatal
Willebanks
Chevy/GMC Duramax 01-04 LB7
Mar 11, 2022 07:12 PM
Jet A Fuel
6.7 Liter Dodge Cummins 2013+
8
Oct 21, 2015 03:30 PM
Jet A Fuel
Aug 3, 2015 10:45 AM
Jake12valve
May 10, 2015 11:57 PM
carid
Diesel Bombers Sponsors
Dec 12, 2014 02:26 AM
