4gsk ?
Old Feb 16, 2011 | 04:19 PM
CumminsKid6's Avatar
Default 4gsk ?
I have a 95, with a 5 speed 0 fuel plate all the way forwards and star wheel turned. 4 inch dp to 5 inch into 8 inch stack. Cold air intake. And a home ported intake elbow. How much difference will a four k spring and 60lbs valve spring make on my truck
Old Feb 16, 2011 | 04:47 PM
Whit's Avatar
Site Mascot
about 1500 rpm diff
seriously myself I think 4k is too much but about 3200 is just right
so basically to answer yer question what you will have is a broder power range.................1800-4k
Old Feb 16, 2011 | 06:07 PM
billy-bob's Avatar
The 4ks really wake it up. even if you dont want all that rpm,it fuels all the way through the power band instead of falling off at 2200
Old Feb 16, 2011 | 07:54 PM
monster12valve's Avatar
night and day diff
Old Feb 16, 2011 | 08:55 PM
So in other words it'll be pretty bad for what I have done so far. And it'll have better power forwards top end. Will it make it idle different. And would u recommend a aftermarket harmonic balancer. If so which one
Old Feb 16, 2011 | 10:24 PM
95.12v.Cummins's Avatar
Old Feb 17, 2011 | 02:16 PM
1AMatt's Avatar
Site Sponsor - 1aauto
Do the 4kgs and bump your timing up a couple degrees and your truck will haul
Old Feb 17, 2011 | 03:30 PM
BRE's Avatar
BRE
I have 3k's and have driven several trucks with 4k's and it is most def. a night and day difference. As 1AMatt said a little timing bump would be in order as well.
countryboy040993
22
Nov 12, 2014 11:25 AM
