High egts really confused now
Old Feb 16, 2011 | 08:15 AM
dan33klein's Avatar
Default High egts really confused now
Hey guys I've asked about this before and now I'm really confused.
I'm running really high egts going Down the road and when I barly get in the throttle.
Everyone and myself was blaming this on my hx40 turbo I have on top. But my buddy just rebuilt a 12v and put it in his truck. He also threw a ht3b under his hx 40 . Same setup as mine. I preached to him for 2 weeks saying hes wasting his time and he's Gunna have the same problem I have. Now his motors running and it runs smooth and about 650-700* down the road. We have the same setup but his is running right and now I look dumb for saying it wouldn't work. So what could be my egt problem? I not ruling out the turbo. But his is working fine with it. Any help appreciated I want to figure this out
Old Feb 16, 2011 | 08:53 AM
Dallas Flywheels's Avatar
You sure your pyro is reading correct??
Old Feb 16, 2011 | 08:59 AM
Whit's Avatar
Site Mascot
when you did the twins was there any other mods you did at the same time?
Old Feb 16, 2011 | 09:12 AM
5.9sledhead's Avatar
Ya I'd pull out your pyro an try a different one.
Old Feb 16, 2011 | 10:55 AM
94 12valve's Avatar
bigger tires and the lift?
Old Feb 16, 2011 | 11:21 AM
Farmboy 2.0's Avatar
Have you checked to make sure both turbos are moving freely? What are you running for a air filter?
Old Feb 16, 2011 | 06:22 PM
dan33klein's Avatar
Bhaf. and when I had my 35/40 hybrid up top it had good cruising egts. There bad when I put on the 40. So I'm blaming that. But my buddy's got the same setup and his is fine. His is lifted with bigger tire to. I switched to 410 gears and it never made a difference. Should I look into my pyro? It's out of Warrenty. Idk what to look for
Old Feb 17, 2011 | 12:38 PM
Bkey's Avatar
i would ask your freind that runing the same turbos to us his pyro and gauge and just put it in and see what his is reading on your truck and like scott@alligator said make sure that your turbos a sping free you may have gotin a bad turbo good luck
Old Feb 17, 2011 | 02:05 PM
12valvetater's Avatar
Are you sure he has the same 40 and 3b?
Old Feb 17, 2011 | 02:26 PM
dan33klein's Avatar
exact same 40 and ht3b. same size hot pipe and all. both turbos are spinning freely. they have been high since i put them on. maby i can get his egt guarge if it isnt a big hassle for him.
