FUEL PIN ?
Old Feb 16, 2011 | 12:29 AM
sweetv8s10's Avatar
Default FUEL PIN ?
I was wondering what pin would be good as far as egts since I pull a trailer alot?
Old Feb 16, 2011 | 01:10 AM
Yellow Yota's Avatar
Well, if you're looking for EGT's in the stock temp range, and having a truck that you just can't over heat, I'd recommend the stock one!
If you add fuel, you'll need to be careful. Especially when towing. I'd suggest loosening your star wheel a bit, installing a 366 spring, rotating the stock pin to the deepest spot, and running the fuel screw in a turn or so. Try that. See if it is enough for you.
You can walk through a stock clutch or really **** of a stock transmission with just simple pump mods.
I assume you have already installed a set of gauges. If not, put that at the top of your list since you tow.
Old Feb 16, 2011 | 08:24 AM
white93's Avatar
It also depends on how heavy you tow. I pull some really heavy loads sometimes and I got to the point where I just put my truck back to stock fueling(almost). I did what yoda said with the stock pin and half turn on the screw. With that set up its alot better but i still have to keep an eye on the pyro going up small hills and accelerating. I still can't do wot with a load but I also don't peg the pyro with 1/2 throttle anymore
Old Feb 16, 2011 | 10:27 AM
crewcab59's Avatar
I went with the m&h #2 and have my afc spring all the way up and it works great. my trailer weighs about 9000lb loaded. this allows the fuel to be regulated at low boost, (it seams to make a bigger window to pull in with out extremely high egt's) until the spring has been over come by boost, then you have max fuel possible. my .02
Old Feb 18, 2011 | 09:29 AM
justanother92's Avatar
Ill be getting the stage II soon from dennyt and ill let you know what it does to my egt's i am alsot looking at the sdx Stage II injectors i think i will be upgrading turbo soon after Lol. And i just ordered a 3200 spring yesterday so all in all it should run like a soon of a gun. haha hopefully without tranny failure.
Old Feb 18, 2011 | 04:15 PM
90cummins's Avatar
i have a denny t stage 2 and my egts or lower than i thought they would be. they are about 850--900 when i put it to the floor.
Old Feb 19, 2011 | 08:18 AM
slingshot's Avatar
I have a stock pin that I ground down, modeled after wannadiesels pin (on DTR) and I love it.And it was free.I cant imagine ever needing to go back to a stock pin, but if I do, They are plentyful through salvage.
Old Feb 22, 2011 | 01:37 AM
big bad diesel 416's Avatar
Site Sponsor
that pin that Denny T makes is hard to beat
Old Feb 22, 2011 | 07:17 AM
KD93's Avatar
Either M&H #2 or one of Denny T's profiles. (Not sure which one.) Or, the stock one with a bit of a home grind. As Slingshot said, it's FREE!
Old Mar 24, 2011 | 08:11 AM
Levi Miller's Avatar
i run a m3 and its pretty good if you want il send it to ya for 75 i want to get an m4 or 5
