steering box removal
Old Feb 15, 2011 | 09:44 PM
Red_Rattler's Avatar
High Tech Redneck
Default steering box removal
First things first lil background. Had the truck come into the shop with little to no steering. After looking at it I saw the whole steering box was pivoting away from the frame when steering was applied. (busted bracket to the frame) To my surprise it was still avalible and only 18 bucks so heres a quick and dirty on getting the box off of the truck.
First thing is looking what im dealing with and what I have to clean. Truck only has 80k on it
One of the 3 bolts that hold the bracket to the frame, but this bolt in particular is pressed in so the nut has to be removed from the back and hammered out.
Cleaned up now I can see the fittins and nuts and bolts Im dealing with. Lines are 18mm Drag link I used 1 1/16" wrench for the castle nut. Took a fire wrench since the lines were froze to the nuts and a air hammer with a fork attachment for the drag link. A hammer and punch is also used to remove the drift pin for the steering shaft.
Everything disconnected
Removed and now you can see the 3 bolt holes and locations that need to be removed
While your there check the steering joint, this ones toast!
The real issue NEW vs. OLD
Like I said the truck only has 80k but shes been run hard and has the dents to prove it. I'd love to save the truck but the guy who owns it thinks its worth 10 k.... Maybe to him but not me
Old Mar 2, 2011 | 03:28 PM
jdbigblue12v's Avatar
had the same problem with the steering bracket. seems to be a common problem there is a reinforcement plate available for 40$ i can see my self purchasing one in the near future
Old Mar 2, 2011 | 06:07 PM
Begle1's Avatar
The best directions for getting the steering box off are "air hammer". The only way to get a pitman arm off the splined shaft... And I also ended up needing it to separate all my steering joints and the steering column linkage as well.
After doing the job three times over a weekend because the remans kept being bad out of the box I got quite good at it.
Old Mar 2, 2011 | 08:12 PM
KD93's Avatar
Good God man, that's the nastiest looking box I've seen in a long time! 10k? Tell him he's dreaming.
Old Mar 4, 2011 | 10:27 PM
rcole's Avatar
This seems to be a common problem. I spent almost $50 just to replace my rugged ridge steering box mount. I don't wanna drive my car anymore if it will get busted again.
Old Mar 4, 2011 | 11:01 PM
diesel pap's Avatar
Site Sponsor - Mighty Diesel
i would change that joint to a u joint style too.
Old Mar 4, 2011 | 11:13 PM
High Tech Redneck
Went with the factory setup. Guy didn't wanna spend the money
Antwhite19
Aug 23, 2015 06:07 AM
ramrunner01
Jun 1, 2015 12:10 AM
Boostaddiction
May 4, 2015 06:28 AM
BubbaDT55
Apr 12, 2015 10:47 PM
sweetv8s10
Oct 7, 2014 09:47 PM
