oil pan gasket
Old Feb 15, 2011 | 05:21 PM
kieron_kohlmann's Avatar
Default oil pan gasket
Has anyone changed an oil pan gasket? Service info says to remove the engine, but im wondering if anyone has a trick to make it easier.
Old Feb 15, 2011 | 05:48 PM
timdale's Avatar
I've heard you can lift the engine a few inches to change it. Are u sure it's the pan gasket? Mine was leaking from the front seal and the rear main housing, but it looked like the pan was leaking. Also check the vacuum pump/ pwr steering pump for leaks that run down to the pan, best of luck
Old Feb 15, 2011 | 09:00 PM
joshwebb609's Avatar
Default yes u can
Yeah jack the engine up! Its a pain I dropped a lifter when I put a 215hp p pump on but got it done.
Old Feb 17, 2011 | 10:42 AM
1AMatt's Avatar
Site Sponsor - 1aauto
X2 Lifting the Motor just a couple inches will make the world of difference in changing the pan gasket.
freak-n-diesels
Aug 23, 2015 06:47 PM
CRCSI
Mar 29, 2015 11:26 PM
98cummins
Jan 29, 2015 08:23 PM
BCOWANWHEELS
Wanted To Buy (WTB) - Used
Jan 7, 2015 03:42 PM
98cummins
Dec 9, 2014 10:14 PM
