oil residue in turbo intake pipe
Old Feb 15, 2011 | 06:50 AM
jimrd's Avatar
Default oil residue in turbo intake pipe
I took off my air cleaner assembly and turbo intake plastic pipe to get at the coolant hose that i snapped while taking off the coolant bottle....
I saw some oil in the plastic intake tube going in to the cast aluminium intake elbow...
is this normal.....the oil was clear and not dirty
Old Feb 15, 2011 | 07:55 AM
Mdub707's Avatar
Yep. The crankcase vents into the intake right in front of the turbo so there is oily residue on all of your intercooler piping and boots. This is why the boots rot away after a while and also why they will pop off sometimes. Just clean the rubber boots up real good and put some hairspray on them, and reattach. usually does the trick if they are popping off a lot.
Old Feb 15, 2011 | 12:10 PM
jimrd's Avatar
thanks
i had to use heat gun on low to get the tube back on the cast elbow
I tried pushing it on and could not slide over the ring
Old Feb 16, 2011 | 07:02 AM
Mdub707's Avatar
Yeah it's a PITA to get back on, but it will go on.
Old Feb 20, 2011 | 12:53 PM
kidn1980's Avatar
thats why people do a ccv relocate.
Old Feb 20, 2011 | 04:42 PM
Diesel_Daddy6.0's Avatar
Would it hurt anything if I pulled that tube out of my piping and just had an atmospheric/roadway dump. Don't worry I don't give a **** what the tree huggers think about my splashed oil going on the road, they can suck on my exhaust tip.
Old Feb 20, 2011 | 07:46 PM
Mdub707's Avatar
It's fine, but you need to plug the hole in the intake with something, and make sure it can't get sucked in, cause it goes right to the turbo. You can search the forums for CCV mod, there's a million different ways to go about this. I'm not completely sold on it, and mine is staying the way it is for now, but that's JMO.
I've seen a couple guys welded fittings on the exhaust downpipe and had it vent into the exhaust so it's just burned off.
Old Feb 20, 2011 | 09:30 PM
kidn1980's Avatar
i have heard of many people do that is as well welding it into an exhaust sounds cool.....i just plugged mine up and went to lowes and bought about 10' of hose and moved it to back
avatardvr
18
Aug 8, 2019 12:38 AM
rodbuilder
Jun 26, 2015 12:48 AM
CumminsCoalRoller24/7
Apr 21, 2015 09:03 PM
MrCat4974
Mar 25, 2015 08:13 PM
jrsavoie
Feb 6, 2015 09:44 PM
