CB Mount
Old Feb 14, 2011 | 10:53 AM
GuyWithA24Valve's Avatar
Default CB Mount
I've been looking at CB mounts cause I'm getting sick of not being able to put my truck into 4 low since my CB is mounted right there under the dash. I saw the CB mount on Genos Garage. Where exactly does that one mount??
I think it would be cool to mount my CB right in front of the center seat so that the face is pointing up, if you can visualize what I'm saying.
Old Feb 14, 2011 | 11:38 AM
blkjack's Avatar
That is where the one from genos mounts. I actually fabbed one up to in the same location.
Old Feb 14, 2011 | 03:35 PM
24vcumminscowboy's Avatar
how did you build yours i want to do the same thing to mine ive never really seen a good enough pic so i could make one
Old Feb 14, 2011 | 04:41 PM
connermcpherson's Avatar
CB/Ham Radio mounts for 03-09 Dodge Ram Trucks - eBay (item 280584530231 end time Mar-03-11 20:41:29 PST)
this is the exact same one i used with my cobra on my 02' and it worked perfect. I mounted it real close to the seat to it looked real flush and almost hidden from view
Old Feb 15, 2011 | 12:26 PM
01_cummins's Avatar
i fab'd my own mount and made it to were it screwed onto the side of the 4x4 shift area i have a 6 spd man though so i don't know if it would have much difference on were you'd want to mound it
Old Feb 15, 2011 | 12:57 PM
blkjack's Avatar
I will have to get a pic of it and put on here,its kinda hard to explain, but i basicly took some of the meatal strap that has the holes in it that are spaced about a inch apart and then the same but in angle and there are two bolts under the seat that bolt the middle seat to the frame and bolted the angle peices to that. Then used the flat to come up infront of the seat to mount the radio bracket to. I was just using that type of metal to mock something up to build something a little better but i ran out of time and just left it and havent messed much more with it. You cant really see the metal at all just looks like my radio is stuck to the front of the seat.
Old Feb 15, 2011 | 09:10 PM
navy_welder's Avatar
Mine is mounted to the roof where the overhead console would be if it came with one and wires ran up the a pillar I screwed it to the brace
Evenglass
Diesel Engine Conversions
389
Jun 18, 2017 01:25 PM
Josh923
Sep 10, 2015 11:16 AM
flyinmonkeys32
69
Apr 30, 2015 12:09 AM
