loping?
Old Feb 13, 2011 | 10:49 PM
dog's Avatar
dog
Default loping?
ok ive seen all sorts of videos on youtube about a cummins loping and I'm sure there's more than one way to make this happen but how?
Old Feb 14, 2011 | 09:12 AM
GuyWithA24Valve's Avatar
Usually larger injector lines (usually on trucks that don't need them it seems like) or just a bigger injection pump like a Monster injection pump
Old Feb 14, 2011 | 09:13 AM
connermcpherson's Avatar
Big fuel and timing and a cam. If you have alot of timing and it can cause your truck to "lope". I have alot of timing and a cam on my truck so with those combinations it hazes and lopes at idle. Also if you get some shi**y injectors like Jammers, they will make your truck lope because the spray pattern is horrible
Old Feb 14, 2011 | 01:05 PM
banditsdiesel's Avatar
they also mack a tune for a lot of the down loaders thats called lop idle software and it basiclly just make the truck fuel iratic at idle and have that big cam sound and clears to normal tune as soon as the pedal is touched.
Old Feb 14, 2011 | 06:13 PM
dog's Avatar
dog
what programmers do this and also is it expensive to do the bigger injector lines
ok so I did some research and found out i cant do any lines bigger than .084 with my auto. and stock vp44 so hee's another question what size are the injector lines stock?
Old Feb 14, 2011 | 07:30 PM
.063. and im not sure of the kinds of tunners that do it. ive never had any need for one or had anyone want one. i dont think its good for the motor myself.
Old Feb 14, 2011 | 07:45 PM
heavy hauler's Avatar
Larger injector tubes will make it lope. These are the tubes that go from the injector lines through the head to the injector itself. .093 are about as big as I would go. Larger injectors will also change the sound of the motor. As far as tuners I dont think any of them change anything at idle. They only chage when you start to build rpm and boost.
Old Feb 15, 2011 | 09:54 AM
they do make that software i have seen several trucks running it. i just will not run it myself.dmaxand cummins common rail trucks run it more than othere because it easier to tune electrionic injection trucks. and it does change the idle pattern which is where the lope comes from but yes big injectors will change it and well as larger connecting tubes. bubt what you have to remember with that is when you do that you can create a vaccum or surge in the fueling and cause the truck to run iraticly. your injection system needs to run smoothly to create power all the way through and make that power smoothly. you need to make sure the system is all matched up to what your needs are. not wel lets throw some big lines on for hte sounds cause that may or can really affect the power you make at any given point.
Old Feb 15, 2011 | 04:02 PM
dog's Avatar
dog
alright guys sounds good i was more curious than anything but i really appreciate the advice
Js1215
Nov 8, 2014 12:25 AM
