Bigger injectors?
Old Feb 13, 2011 | 07:35 PM
camaro 468's Avatar
Default Bigger injectors?
I have a 97 3500 that i bought new, mods-K/N air filter, straight pipe and advanced pump timing, i would to install bigger injectors what are the pros and cons, how big should i go?
Old Feb 13, 2011 | 08:58 PM
Bkey's Avatar
pros are more power and more boost in you dont get out of hand with the size you will get more mpg cons are higher egts i am sure some one with more knowage on these engines will be more help but i will say this i love my 90 ddp injectors i did get about 1.5mpg more out of them just dont get to heavy on the little pedal
Old Feb 13, 2011 | 09:08 PM
camaro 468's Avatar
will i need to get a pryo, will the egts need to be watched with 90hp
Old Feb 13, 2011 | 09:15 PM
Bkey's Avatar
yes i would recomend that highly do you have a bad injetor or are you just upgradeing i didnt see if you had any fuel plate mods if you havent done any thing with your fuel plate i would start there and if you need more after that then do injectors i did my injetor because i had two bad ones when i bought the truck and i have plane to do more with it hope that helps
Old Feb 13, 2011 | 10:44 PM
camaro 468's Avatar
Yes i had a plate mod said to be 60hp about 6 years ago. no bad injectors just wanted more power and to be safe, i parked the truck in 07 and got a new truck \, now im back driving it agine
Old Feb 13, 2011 | 10:53 PM
Bkey's Avatar
ok ya a smaller injector would be a good move i think well i hope i was a help if you have more ? i will be on again soon injetors are not hard to do good luck and i have said this before i like my ddps i have got in my 12v and i put a set of 120hp ddp in a friends 24v he didn't have any milage gain just a sliping clutch he love them and it fun to drive good luck
Militant83
For Sale
Mar 18, 2015 03:34 PM
klein444
Mar 8, 2015 11:42 AM
nate379
For Sale
Feb 15, 2015 03:23 PM
nate379
For Sale
Feb 9, 2015 08:27 PM
strokin97
Sep 30, 2014 11:59 PM
