In need of more reliability
Old Feb 13, 2011 | 06:55 PM
wpg6.5's Avatar
Default In need of more reliability
I have almost owned my truck for a year now and shes still going strong but since winter is almost over i wanna get back to working on her, im curious of what other reliability upgrades i can make, i already plan on a cooling upgrade of some sort and possibly replacing my oil cooler lines since im pretty sure they are leaking. any more help would be great.
Old Feb 13, 2011 | 10:30 PM
Woody35's Avatar
relocate pmd to behind bumper
Old Feb 14, 2011 | 10:42 AM
wpg6.5's Avatar
i could, the original own had already put an fsd heat sink in it on the driver side inner fender. so im thinking it should be ok there.
Old Feb 14, 2011 | 11:01 AM
Crazy's Avatar
need to get out from under the hood
Old Feb 14, 2011 | 01:38 PM
wpg6.5's Avatar
Is there anything else i should be looking at?
Old Feb 21, 2011 | 04:51 PM
ricansdiesel's Avatar
check harmonic balancer and pulley. if these 2 items fail,you might end up with broken crank...ask me how i know!!!
Old Feb 21, 2011 | 06:37 PM
wpg6.5's Avatar
my pulley is original which i probably should look at but my balancer is a fluidamper. brand new.
Old Feb 21, 2011 | 09:27 PM
Woody35's Avatar
make sure all your injectors are pop tested but i think heath does that. as far as that do the cooling upgrade, replace all fluids with synethtic, and maybe think about some arp studs for the heads
Old Feb 22, 2011 | 11:06 AM
wpg6.5's Avatar
i was thinking head studs, i run royal purple in the diff but i wanna get a detroit locker out back my locker slips out of locked. i run royal in the engine and the trans worths mint with a synthetic additive. i was thinking of doing the head gaskets and arps. is their any point getting a thicker gasket? and is the ho water pump neccesary or should i just get the fan? has brand new fluid and 2 new thermostats.
Old Feb 22, 2011 | 10:03 PM
Woody35's Avatar
HO pump is better i dont know if its neccesary but its a defient improvement over the ones we have but if you tow at all i would suggest it. i also forgot to say to deep clean your rad. theres usually a pound of crap stuck in there and it will help your cooling.
thicker gasket will reduce your compression ration which in theory will help longetivity because you are reducing cylinder pressures a bit but it also hurts efficeny. also a bigger risk in blowing head gaskets if you boost too high but i doubt you do that. remember if you do arps to use there lubricant on the threads
Jmohr52
Mar 4, 2015 01:18 AM
mountainmover
Mar 1, 2015 02:47 PM
