Fuel line question
Old Feb 13, 2011 | 02:18 PM
5.9sledhead's Avatar
Default Fuel line question
How much psi does braided steel fuel line hold? I was thinking it would be way easier to use it from the ip to injectors an look cooler too. But got to thinking why haven't I heard of any one else doing it?
Old Feb 13, 2011 | 07:54 PM
Rodburner07's Avatar
um no they wont hold , and thts y no1 has done it
Old Feb 13, 2011 | 08:35 PM
Turbolvr's Avatar
Ip runs 4000psi and the braided lines (IF they hold, but they wont) will "breath" and injectors wont pop. even the steel lines breath some. put your hand on them while its running.
Old Feb 14, 2011 | 11:47 AM
Figured they was a reason thanks guys. How about brakeline fOr injector lines?
Old Feb 14, 2011 | 12:12 PM
Turbolvr's Avatar
why not use injector line for lines?
Old Feb 14, 2011 | 11:49 PM
I want to route them different so to the top side is more accessible.
Old Feb 15, 2011 | 08:25 AM
Turbolvr's Avatar
Old Feb 15, 2011 | 10:34 PM
Perfect thanks a bunch
Old Feb 16, 2011 | 11:59 AM
kmkdiesel's Avatar
if you look around you could probably find a place to make some for you, but to hold the pressures they are probably going to be spendy
Old Feb 16, 2011 | 02:33 PM
cumminspwr11's Avatar
dont they have to be made right to get the injectors to fire right?
