turbo- code..is it serious?
Old Feb 13, 2011 | 09:47 AM
CumminsTurboDiesel's Avatar
Default turbo- code..is it serious?
Last week check engine light came on,had the local diesel guy scan it and the code for turbo wastegate eror came on. We cleared the code and now it came back on. What is causing this? Can't find broken or loose wires to the wastgate solonoid. Its a stock turbo and I've been really easy on the boosts lately. Any suggestions? Thanks for the help
Old Feb 13, 2011 | 10:53 AM
hydroshok's Avatar
Can you hear the wastegate opening or have any other problems while driving? Did you check the map sensor connections?
Old Feb 13, 2011 | 11:15 AM
We checked. The wiring connections. Found no problems that I could see. Whenthe truck is on stock settings I can hit like 28 psi boost. When the edge juice is on stage 5 I've been able to hit like 48 psi.
Old Feb 13, 2011 | 11:34 AM
hydroshok's Avatar
Maybe try taking the edge off, reset the comp and run it for a while. I think mine @ stock is about the same, but I have only hit high 30s to low 40s with the smarty. IMO if there are no problems and your not losing fuel economy don't worry about it. All it is going to do is cost you money. Just make sure you watch that your boost levels don't go too high. I think its 60psi for the stock head studs.
Old Feb 13, 2011 | 11:56 AM
Ill give that a try. Thanks for the help
Old Feb 13, 2011 | 09:16 PM
dangerous1965's Avatar
Get a boost fooler and be done with it!
Old Feb 14, 2011 | 08:13 PM
What is it? How does it work and where do I get it? And will still be able to read actual turbo psi with it installed?I have an edge attitude with juice but no hot unlock code. Thanks for the help
Old Feb 15, 2011 | 07:40 PM
lunk's Avatar
my did that had to replace the turbo cause the waste gate broke putting to much boost through it my was under warranty thankfully. i have been running around stock since then
Old Feb 15, 2011 | 09:50 PM
tinysdodge's Avatar
The code will go off at 45 psi thats what stock is set at i run mine at 44 psi and the alarm at 45 psi and havent had a problem for 80000 kms
Old Feb 17, 2011 | 09:58 PM
cerberus60's Avatar
What is the code that is showing?
avatardvr
18
Aug 8, 2019 12:38 AM
Finn92
Feb 24, 2015 10:41 PM
n2brk
Feb 21, 2015 09:05 AM
tumble72
8
Nov 27, 2014 10:31 PM
GreenDieselF
Oct 20, 2014 02:05 PM
