DAngitT!! NV4500 5th gear clutch ring...
Old Feb 12, 2011 | 06:19 PM
captaincaveman's Avatar
Default DAngitT!! NV4500 5th gear clutch ring...
been through 2 in a week!!!!!!! any ideas?
Old Feb 12, 2011 | 07:25 PM
dolla_hite's Avatar
are you talking about the 5th gear nut backing off the shaft? if so have you tried tack weld the nut to the shaft.
Old Feb 12, 2011 | 07:33 PM
heavy hauler's Avatar
Put a newer style nut on it. It will be split with a set screw in it. A friends came loose 3 times in a month and he installed the newer nut and not had anymore problem in 4 years. And you also need to tighten it as tight as you can get it. If you think you got it tight enough get it tighter.
Old Feb 12, 2011 | 08:00 PM
It's not the lock nut...that's already been upgraded. its the 5th gear clutch ring, right under the lock nut...#73 on here
NV4500 Transmission Exploded View
Old Feb 12, 2011 | 08:31 PM
cummins95's Avatar
i ripped the teeth off my clutch cone not too long ago. i dont know if quad4x4 would have any type of after market piece but they sell a replacement. it just seems like a poor design to me that they would make 14 ( or however many are on it) splines 1/4" long hold that power... only thing i can say is try to be easy on 5th gear. i've started leavin mine in fourth alot more cuz im gettin way too good at pullin the transfer case outta my truck
Old Feb 12, 2011 | 11:25 PM
that's exactly what happened. Twice in 4 days. There are CHEAP aftermarket parts. And the OEM replacement is redonkulous expensive, but must not be that great, I just shredded 2 of them. Is there an aftermarket upgrade?
Old Feb 13, 2011 | 09:09 AM
cummins95's Avatar
i bought mine from allstate gear. it was somewhere around 50 bucks. n so far its holdin up.
Old Feb 13, 2011 | 09:21 AM
how long has the new clutch ring been in?
Old Feb 14, 2011 | 07:22 PM
cummins95's Avatar
its been in about 2 1/2 months now. i've started down shiftin to 4th under 1700 rpms now to relieve some stress on it
taweste
Sep 10, 2015 09:16 PM
klu408
Price Quote - Request A Price
Apr 26, 2015 07:28 PM
99&91cummins
Feb 28, 2015 09:28 AM
miked2805
Oct 29, 2014 06:20 PM
offroad00
Oct 21, 2014 01:48 PM
