3 codes please help!!!
Old Feb 11, 2011 | 12:01 PM
01_cummins's Avatar
Default 3 codes please help!!!
i have three codes on my 01 dodge 2500 24v HO cummins with 6spd manual.
1)P0216, injection timing timing control circuit malfunction
2)P1689,controller area network bus failure(no communication between CM551 and VP44 pump module)
3)P0121, Throttle/pedal position sensor/switch A circuit range/performance
i have them under another thread but i decided maby i should put in on here becuase the other thread isn't related to two of these IMO....and i need all the help i can get
Old Feb 11, 2011 | 12:10 PM
Whit's Avatar
Site Mascot
this isnt good
so how is the truck running?
Old Feb 11, 2011 | 01:21 PM
01_cummins's Avatar
it runs allright going down the road i usualy set cruise when ever i can becuase it backs off to idle becuase of the TPS issue. im gonna pull the secondary fuel pump and see if that is cuaseing the VP44 problem becuase i hadn't had the other two codes untill i put it on. it still has power and i can't hear it missing the only code i thought id get was the TPS when i scanned it.
i don't even know what the P0216 and the P1689 codes are telling me ...so if anybody could suggest the problem behind them that would be great!!
Last edited by 01_cummins; Feb 11, 2011 at 01:21 PM. Reason: Automerged Doublepost
Old Feb 11, 2011 | 01:26 PM
Whit's Avatar
Site Mascot
I think yer VP44 is on its way out
Old Feb 11, 2011 | 08:21 PM
01_cummins's Avatar
oh shoot...would it be wiser to try to find a wrecked truck with front end damage? that way i can get a TPS and a VP44? well if i could get the thing for like 1500 or so? cuase i think the TPS is on the way out the door too.....
Old Feb 15, 2011 | 06:03 AM
chadcycle 2500's Avatar
Tps can cause a lot of trouble all by itself,ceck your pressures my acted real irratic just off idle, heavier throttle was ok,did not show a code for it said another one, changed tps 300.00 runs perfect
Old Feb 15, 2011 | 11:52 AM
01_cummins's Avatar
were'd you get a tps for 300 bucks?? i priced it at 420 at the local oreilys
Old Feb 15, 2011 | 01:06 PM
blkjack's Avatar
I bought one from here last year had some similar issues with mine. I paid $160 for mine shipped. Havent had a bit of trouble with it since. Timbo APPS Alot better than 300-400.
Old Feb 15, 2011 | 03:48 PM
banditsdiesel's Avatar
im thinking the psg on the pump is dead or about to be. if its bad it can cause tps issues as well. and it with a communication code too, makes me think pump more than anything else.
Old Feb 15, 2011 | 08:31 PM
Auto Zone
longhorn12
6.7L Performance
Aug 29, 2015 01:28 PM
schwier94
Mar 8, 2015 06:09 PM
KimberlysTruck
Mar 5, 2015 06:28 PM
Renowest48
Dec 14, 2014 08:36 PM
Altonlee
9
Oct 8, 2014 02:31 PM
