crank sensor or what?
Old Feb 9, 2011 | 08:08 PM
Sawman's Avatar
Default crank sensor or what?
When I am going down road my truck will miss, when the check engine light comes on and the tach dies. As soon as I turn truck off to read codes the check engine light goes out and no codes will show up. I have been told this is the crank sensor, I would like moe opinions before I start replacing things.
Old Feb 9, 2011 | 08:11 PM
diesel pap's Avatar
Site Sponsor - Mighty Diesel
thats what it sounds like to me.
Old Feb 10, 2011 | 02:03 PM
01_cummins's Avatar
also could be your throttle position sensor...does it do that if the cruise is on? if it doesn't with the cruise on that might be it. if the TPS is out it will cut back to an idle when ur accelerating and u pump the pedal it lights back up or it will just dead pedal on ya. also after it does it 3 times before your truck is started and shut off three times your truck saves it to the archives and you will be able to read it with the scan tool. the part were you cant read it with a scan tool is kinda wierd....hope its helpfull for ya! goodluck
Old Feb 10, 2011 | 08:03 PM
Sawman's Avatar
That was it!!!!!!!!!!!!!!!!
ish1521
Aug 26, 2015 08:42 PM
Paladin
Jul 26, 2015 03:59 PM
tmcc14
Apr 21, 2015 03:59 PM
Polaris04
Dec 1, 2014 08:27 AM
weatherby
99-03 7.3L Performance
Nov 5, 2014 10:45 PM
