Trying to find leak in return line.
Old Feb 9, 2011 | 04:36 PM
KiltEmWhooptem's Avatar
Default Trying to find leak in return line.
ok i have had a hard start problem ever since replacing fuel pump with airdog i parked my truck nose down on a hill it starts fine no matter how long it sits. im looking for the bonded seal washers for my banjo bolts they looked real messed up but i need to no what sizes to order and how many. also if this doesnt work is there anyway to find out how air is getting in the lines. thanks
Old Feb 9, 2011 | 04:48 PM
D-LUX's Avatar
im pretty sure Vulcan performance sell some 90* fittings that replace the banjo bolts and get rid of the sealing problem they have hope this helps
Old Feb 10, 2011 | 09:59 PM
kingbrad89's Avatar
I had the same prob with my airdog. I checked everything... Turned out it was the last thing I ever expected, a bad seal on the fuel filter! Replaced the filter and problem solved
Old Feb 12, 2011 | 08:32 AM
98.5cummins's Avatar
I have the 150 on my 98.5 and have always had hard starting issues when it was first started in the morning. I found when I put a toggle switch to cut the pump power when cranking it would start fine. I've been doing this for 4 years and haven't replaced the VP44. I believe it is too much fuel pressure for the pump when cranking, but only when it's cold. Once it's warmed up it will start. FASS has instructions for there pump on how to wire it up to the window relay so power will be cut. I would not recommend that. I did get a ECM update from the dealer which changed the timing of the lift pump when cranking. If you use a switch, MAKE SURE YOU REMEMBER TO TURN IT BACK ON WHEN IT STARTS! It will run with out fuel pressure. Hope this helps
Old Feb 12, 2011 | 10:16 AM
kingbrad89's Avatar
It sounds like you have a wiring issue. The airdog should not be actually running while the truck is cranking, it turns on for a brief second when you turn the key to run and should shut off almost immediately. If it's running while cranking that's too much pressure and it won't start.
Old Feb 12, 2011 | 11:40 AM
yeah, it was my ECM. It used to prim for 5 seconds, but when i got it udated at the dealer it only comes on for a quick second. It good to hear that someone else knows what i'm talking about.
|WYG|SS
May 7, 2015 04:57 AM
|WYG|SS
Apr 28, 2015 03:59 PM
CumminsCoalRoller24/7
Apr 21, 2015 09:03 PM
4x4kingx889
Jan 25, 2015 02:02 PM
Dec 5, 2014 08:30 AM
