newie ques
Old Feb 9, 2011 | 02:21 PM
johnnyreb's Avatar
Default newie ques
I just came aboard to forum and have a few questions. I've used the search function and read most of today and now it's clear as mud. I've got a bone stock 93' D250. Only thing i've done is pull off the muffler. I fixin to build and install an "old smokey" air intake. I was also thinking about the 3200 pump spring. I'm looking to boost my power when pulling a horse trailer down the interstate without a lot of smoke or killing my mileage too bad. I've read on turning up my pump and it seems a bit intimidating. I need to stay on the cheap(wife,2kids, one pay check). So i'm looking for any and all suggestions from everyone.
Before someone asks, yes I ahve mechanical skills, been wrench turning all my life, as well as a machinist, carpenter, and e.m.t.
Just wanting to upgrade
Old Feb 9, 2011 | 04:16 PM
bigbrowngoat's Avatar
your on the rite track with the cold air intake and the open exhuast line . but if your not 100% comfortable mess'n with the ve pump take to to someone that is. plus get a dennyt fuel pin a little over $100 buck plus a good fuel addative . hope this helps ya some
Old Feb 9, 2011 | 05:29 PM
KD93's Avatar
BBG's suggestions are good, but one thing about the VE is that if you don't like something you've done to it, you can always turn it back to how it was. If you've been wrenching a while, there's nothing intimidating about the pump. There should be good info in the sticky, but you should check out other forums too. I may get in trouble for listing some sites in the open forum, (not sure on this site, I have to read the rules again!) so I'll PM you. Also, check on youtube for 'VE turn up' or somesuch. Apparently there's some good stuff on there too.
Also, as Goat suggested, a fuel pin will help you a lot. Either Denny T or M&H make quality products. In saying that, the first thing you should buy is, at minimum, a pyro and boost gauge before you do anything to the pump.
Old Feb 9, 2011 | 08:48 PM
johnnyreb's Avatar
Yeah from what i read today the M&H M3 or M4 seem the way to go. I'll look into it and the gauges. Just trying to keep it mild for now.
Old Feb 9, 2011 | 09:07 PM
RSWORDS's Avatar
Gauges, a small timing bump (less then 1/8"), 3200 spring, DennyT Stage 2, intake, exhaust and a little bit of full power screw would waken that thing right up.
Oh and
Old Feb 10, 2011 | 07:21 PM
johnnyreb's Avatar
Evening all. My old smokey mount plate is cut and bent and just needs the 5" hole in it. So well on my way to getting her breathing better. still looking at gauges and trying to decipher, like to go with VDO, but my solicite advice on that. Discussing with my chief engineer and welder (Dad) on a 4" exhaust with a turn out at the back wheel.
What difference would it make if I rotated the fuel pin and lowered the star wheel 1 1/2 turns? And how do you bump the timing on these engines, I know it's not like my old 289 falcon? A little bit of power screw?? 1 turn or less or more that one turn? I know to watch for run away and have the 2x6 ready.
Old Feb 10, 2011 | 08:37 PM
big bad diesel 416's Avatar
Site Sponsor
before you go crazy with full power screw and all that you need gauges there about 200-500bucks depending on how fancy you get thats cheep insurance VRS the alternative of a melted/stuck piston
Old Feb 11, 2011 | 02:49 AM
Mike337's Avatar
Welcome Reb,
I'd suggest reading all the back posts here and on
Dodge Cummins Diesel Forum
Dodge Diesel - Diesel Truck Resource Forums - Powered by vBulletin
Before you buy or touch a thing. There are some low cost air intake up grades in the stickys as well as tuning info. You'll also find gauge install info.
Old Feb 11, 2011 | 07:29 AM
johnnyreb's Avatar
I haven't touched anything yetand I am in the process of upgrading my air intake.
I've read alot of the back posts on here and joined diesel truck resource forum too.
As i've saidworking on airand exhaust first. Right now i'm asking questions and gathering knowledge so when i'm ready i'm not stumbling around in the dark. Hence my questions on turning the fuel pin and adjusting the full power screw before getting gauges.
Knowledge is power.
Old Feb 11, 2011 | 12:16 PM
slingshot's Avatar
Gauges should be first, i'd say. I understand needing to go cheap, so may I suggest possibly going to a big truck salvage yard and resourcing a pyro and boost gauge out of a wrecked Peterbilt or Freightliner or something.
I happen to own a Peterbilt and a Freightliner, and the gauges in my Dodge are spare gauges I had for my Pete.
I made my own gauge pods for mine and they look good.
