RPM's too high
Old Feb 9, 2011 | 11:15 AM
Dieselfunohio's Avatar
Default RPM's too high
Ok, So I have 4.10 gears and mostly stock engine because I havn't had time after work to open this baby up. It idles about 500 which isn't bad but I have to get around 1800-2000 before the truck will start to pretend to have power. and cruising at about 70mph the RPM's are all the way up at 2800. What can I do to get back into the power range of 1600 when cruising. I want the power and be able to smoke a little but still get gas mileage in the upper teens.
Old Feb 9, 2011 | 11:22 AM
Whit's Avatar
Site Mascot
taller tires..........you can fit up to a 35" tire , will cahnge yer rpm/speed enough
with a 35 you may need to do a 2 inch lift in the front on the springs only, they make a spacer cheap
Old Feb 9, 2011 | 05:17 PM
I have a 3 inch body lift kit in the garage but after reading about cutting steering link conectors and some other stuff, i chickened out.
Also, my boost is only at 5-10 lbs. In 4th gear I can get 20 if I hammer on it
Last edited by Dieselfunohio; Feb 9, 2011 at 05:17 PM. Reason: Automerged Doublepost
Old Feb 9, 2011 | 05:31 PM
bluedieselram's Avatar
put a leving kit on it with 33-35s thatl help ya my 95 used to do the same only it did 2400 rpms before i put my 33s on it
john grossman
10
Jan 12, 2019 08:58 PM
ramrunner01
9
Jun 4, 2015 03:34 AM
Blackdog15
May 20, 2015 10:49 PM
robbyS
Apr 16, 2015 02:22 PM
gvanevans
Dec 26, 2014 04:39 PM
