1999 cummins making driving me nuts
Old Feb 8, 2011 | 09:36 PM
nodnarbtruk's Avatar
Default 1999 cummins making driving me nuts
So Im working on my friends truck, its a 1999 cummins with bigger turbo ,100 hp injectors, dragon flow pump, edge comp unlocked. It has a dead pedal sometimes, let off for a few seconds and then it comes back for a few. Checked codes with smarty and it had apps and the companion code I think it was p1693. So we tried adjusting the sensor no go, tried to recalibrate with key off push pedal ect.,swapped with his brothers 98 and still same. So we think we need new ecm, just wondered if anyone had any ideas. Having trouble finding another ecm. And to top it off I think we'll be changing a head gasket on it as well.
Old Feb 8, 2011 | 09:52 PM
dukeboy_318's Avatar
I doubt its your ECM, you would have some type of code. check you wiring and grounds. Have you tried un-installing the smarty and edge comp? sometimes when these boxes malfunction, itll do wierd stuff to the computer controls. Completely remove the harness and everything
Old Feb 9, 2011 | 10:04 AM
wishlist's Avatar
Had the same problem and it was a ground on the passenger side battery that just barely wasn't connecting. Good Luck
Old Feb 9, 2011 | 10:11 AM
DieselWeasel's Avatar
"Ohio Bombers" Director
Default Re: 1999 cummins making driving me nuts
Not sure on dead pedal BUT if he has all that gear on it and didn't stud the head.... Your probably very right on the head gasket replacement remark.
Sent from my DROID2 using Tapatalk
Old Feb 9, 2011 | 10:44 AM
Did you clear the code when u swapped the sensor?
Old Feb 9, 2011 | 08:10 PM
We did clear codes we also had a friend come over with code scanner to try that as well. I forgot to say the truck does have arp studs. Going to check all the grounds, connections and try again, will let you know what happens.
Tried again, checked all the grounds and connections runs fine till the check engine light comes on then drops to an idle. If you let off the throttle for say 10 seconds you can get back on it for around the same time. The codes that keep coming up are p0230 which I know is lift pump and this truck has fass fuel on it but the other 2 that are there are p0122 and p1693.Clear codes and it seems fine till light comes on again, runs longer when cold seems to lose it when it ges warmed up. Any other ideas would be great thanks, Brandon
Last edited by nodnarbtruk; Feb 9, 2011 at 08:10 PM. Reason: Automerged Doublepost
Old Feb 11, 2011 | 10:29 AM
So after talking to local dealer they think I need new ecm too, any ideas where to get a good deal on one or if you can reflash a used one.
Old Sep 14, 2011 | 11:11 PM
KORDISH's Avatar
You ever get this figured out?
Old Sep 14, 2011 | 11:55 PM
After lots of frustration my friend decided to p-pump his truck so sort of,now he just has to get a twin turbo setup to make it run right.
DirtyDiesel58
18
Sep 27, 2015 07:07 AM
PeteBug
Jun 11, 2015 12:16 PM
Bwerks1797
Apr 2, 2015 08:26 AM
oilfieldguy
Feb 9, 2015 07:42 AM
iam1746regan
Dec 21, 2014 05:06 PM
