lift pump code.
Old Feb 8, 2011 | 10:11 AM
Cumminsdriver's Avatar
Default lift pump code.
Hi. My wires 04 is throwing a code for " low voltage sensed at lift pump". Does this mean that her ll is bad or could there be another (electrical ) problem. I read this code with my amarth from my 05. Anyone with experience with this problem please inform. I am considering replacing with aftermarket pump. Or use my 05 pump om her truck and upgrade mine. Thanks in advance.
Old Feb 8, 2011 | 02:22 PM
gosperformance's Avatar
FormerVendor
That's a bad pump. Might be intermittent. When they start to go bad internally they pull to much amperage and will set the code. Her pump is on the back of the fuel filter housing, your 05 is in the tank. Not saying it won't work but would be a pain to swap everything and then figure out how to plum it into the port on back of bowl. Let me know if you want some pricing, I'd be happy to pm them to you.
Old Feb 8, 2011 | 03:26 PM
CreeperSleeper's Avatar
My pump was getting weak so I finally stepped up to an Airdog. IMO it is worth the extra money.
HeavyChevy95
Dec 21, 2016 10:36 PM
twinturbo12v
5.9L CR Performance
Nov 26, 2015 02:06 AM
landon025
Sep 8, 2015 09:21 PM
Renteria1217
Apr 16, 2015 11:38 PM
klein444
Feb 21, 2015 10:33 AM
