Gear Ratio??
Old Feb 6, 2011 | 05:22 PM
hedgehorn's Avatar
Default Gear Ratio??
Tell what gear ratio I have? I looked at the window sticker and it says that I have the locking diff but no ratio is stated there. I know at 70mph the rpm is at 1750. Its a six speed auto 2011 2500 4x4
Old Feb 6, 2011 | 09:40 PM
CrazyLadysHubby's Avatar
My guess is you have 3.73 gears. My 07 runs about the same rpm for that speed
Old Feb 6, 2011 | 10:10 PM
cumminscontrol's Avatar
my cousin showed me a trick in his mustang that a performance dealer told him to do to see what rearend he had...since that car is a 5spd they said to drop it in 4th, run it up to 73 mph and see what the rpm's say...it was settin dead on 3, which would make it a 3.73...i tried it in my truck, the one in my sig, it bein 6spd, i dropped it in 5th ran it up to 73, and there it was...sittin on 3 on the tach....hope this helps ya....never knew it myself til then
Old Feb 6, 2011 | 10:15 PM
dodgeram082500's Avatar
What size tired do you have
Old Feb 7, 2011 | 05:26 AM
hedgehorn's Avatar
Sorry I should have posted tire size. They are 265-75-17. Thanks for the replies
Old Feb 15, 2011 | 01:49 PM
redruM's Avatar
best way to know for sure is to lift the rear end, turn the tires 1 full turn, and count the revolutions of the driveshaft
Old Feb 15, 2011 | 03:40 PM
jmac5058's Avatar
If you have your list of options and you have DMEP that means 3.73 gear ratio.EJT=cummins DG7=6-speed auto.Im not sure of the codes for other ratios.I know that GM has all codes on a sticker on the glove compartment door but not sure if Dodge does the same.
Old Feb 15, 2011 | 07:03 PM
coors_man_2005's Avatar
should have a tag on one of the bolts on your diff cover also if it hasnt been apart and left off
Old Feb 16, 2011 | 08:06 PM
hedgehorn's Avatar
Thanks for all the replies. 3.73 it is.
Old Feb 24, 2011 | 10:37 PM
EasternAggie's Avatar
This wouldnt work with every vehicle though, because every vehicle has different size tires and different trannys (thus different gears).
here's a formula for the OP.
rpm=(mph x gear ratio x 336) / tire diameter
Final drive on a 68RE is 0.62 btw.
RPM=(70x0.62x3.73x336)/31
RPM= 1755
so at 70mph with 3.73's and 31" tires should be running about 1755 RPMs. Sounds about right.
