6.5
Old Feb 6, 2011 | 03:33 PM
atver27's Avatar
Default 6.5
is there anything bad about the 6.5 i was thinking about getting a 1995 6.5 and whats the good
Old Feb 6, 2011 | 05:17 PM
wpg6.5's Avatar
there can be depending on shape and model. if its been treated right you shouldnt have too much issues. glow plugs and injectors are lifed items and like to go if they are old. injection pump and lift pump can crap out on you. and on newer versions(97-98) blocks can crack and heads can crack. if you dont drive it like a cummins you will be fine.
Old Feb 6, 2011 | 07:06 PM
atver27's Avatar
its in a good condition it a 1995 with 1600000 miles the only bad thing is in needs a new head gasket
Old Feb 6, 2011 | 09:25 PM
Crazy's Avatar
sh|t i drive my truck like cummins
well atver if you do few mods to it. it treat you right the 6.5 are good motor no not going get the power like cummins
head gasket can be problem but if fix it right it last you when you replace head gasket throw the bolts away and go with ARP studs and with that few mods it be good truck
Old Feb 6, 2011 | 10:48 PM
2MuchJunk's Avatar
Everyone I ever had I ran the crap out of and they did just fine. There are some problems with the 6.5 but most of them have been blown up to JAWS proportions. In reality if you take half way decent care of them and do some mods they will be fine. If you get the truck when you replace the head gasket make sure the deck and head surface are flat and not scored. Ignore the cracks between the valves it is just a surface crack and will not leak water and put head studs in it or in the vary least replace the head bolts.
Old Feb 7, 2011 | 07:10 AM
atver27's Avatar
thanks for the help i was thinking i would do the head bolts right away
how bad is it to replace the head gaskets on one
airspeed181
Jan 19, 2015 09:00 PM
Levis95
Jan 11, 2015 01:54 AM
Snoobly
Dec 11, 2014 11:59 AM
bdemutis
Dec 7, 2014 01:36 AM
bdemutis
Nov 28, 2014 08:16 PM
