hx35/40
Old Feb 6, 2011 | 11:30 AM
ltr450's Avatar
Default hx35/40
i was looking at putting the 60mm wheel on my hx35. but it needs machine to fit. can i do it my self with a grinding bit. also is there a trick putting it back together so i don't have to get it balance
Old Feb 6, 2011 | 11:37 AM
RAW's Avatar
RAW
I asked the same thing a while ago, this may help you:
https://www.dieselbombers.com/5-9l-2...machining.html
Old Feb 6, 2011 | 12:11 PM
ltr450's Avatar
ok thanks. so the machining is know big deal. also did you have yours rebalanced
Old Feb 6, 2011 | 01:12 PM
RAW's Avatar
RAW
I haven't done mine yet. in theory, every wheel should be balanced on its own, allowing it to be installed at any position on the shaft.
Old Feb 6, 2011 | 01:26 PM
ltr450's Avatar
thats what i thought that the wheel should be round so there should be no need to balance it.but i have been reading post and some guys balance them and some don't.
Old Feb 7, 2011 | 08:56 PM
Bkey's Avatar
i know that power strokes and cummins are different but when i did my psd i put a differet intake wheel on it and i didnt have it balance and it is still on the road that was about 8000 miles ago and i was NOT NICE to that truck and i was makeing over 35# boost and it still is as far as i know the wheels are balance seperate from each other hope this helps
D-350 dually
Feb 6, 2015 05:41 PM
