Master cylinder
Old Feb 6, 2011 | 08:00 AM
alpetjr's Avatar
Default Master cylinder
In my booster is the push pin for the master cylinder. My pin is adjustable. If I turn it out some will it make my rear brakes work more? My rear brakes hardly work.
Old Feb 8, 2011 | 12:45 PM
Subliminal's Avatar
Have you properly adjusted the back brakes?
Basically you lift the rear (both sides) then pull out the little rubber nubbin on the inside of the drum backing, and rotate the adjusting wheel (down) until they tighten up, and then loosen them till they're barely free. You might also want to bleed it all out, while you're back there, and also bleed the RWAL on the rear of the frame.
Old Feb 8, 2011 | 03:01 PM
alpetjr's Avatar
Yes I have
ILLUSHA
Diesel Engine Conversions
10
Aug 21, 2015 05:48 AM
bryan0702
Mar 18, 2015 05:03 PM
Kennyw250
Jan 14, 2015 07:47 PM
RamCamel
Dec 14, 2014 08:12 PM
Oct 31, 2014 08:10 AM
