No Overdrive
Old Feb 6, 2011 | 01:03 AM
tan0892's Avatar
Default No Overdrive
I bought a truck that did not run. (ran out of fuel) Got it started ran fine but needed transmission lines (he looped the two ends to make it completed bi-passed cooler) He did not pull any trailers with it since he did that. I replaced the tranny lines and its started shifting badly but did shift to overdrive. So I changed the transmission fluid and filter figuring there was crap in the cooler that clogged the filter. After that, it ran fine for a day and then it just stopped working. (No overdrive)
Symptoms include:
Hard start cold, white smoke then clear (think it needs fuel lines)
Cruise control acts like accel button is held down
Tranny fluid was foaming at freeway speeds (65-70mph got off within 2 miles never did freeway speeds since)
Lock up does work
Stalls when cold into gear but then fine after warm (does not stall if let truck warm up good-Live in WI)
Can it be?
Torque converter
TPS
PCM
Temp Sensor
or something else?
Where should I start?
Old Feb 7, 2011 | 09:12 PM
Bkey's Avatar
sorry cant help with the trany problems but i had the same problem with my engine i set my timeing and it made a world of diffenece with the way is starts and run hope someone eles will be more help with the trany problems good luck
Old Feb 8, 2011 | 02:18 PM
dodgecummines12valv's Avatar
hey man it has to be the torque converter and proble the over drive button went out to i had the same proble with mt 2002 dodge cummins and also check the boost boots were it hooks to the inter cooler
450r racer
8
Dec 21, 2015 06:42 PM
FF131
9
Mar 26, 2015 07:06 AM
Legato
Jan 23, 2015 09:15 PM
thetrot
Jan 15, 2015 09:51 PM
Canadiancummins93
8
Dec 10, 2014 09:03 PM
