abs light is blinking
I would pull your rear pan and check your gear teeth. If your teeth are good its probably a sensor. My buddie had a jeep that was blinking his abs light, and he had actualy sheared off a tooth, it still drove ok, but the sensor was getting bad readings. ( IMO If your gears are good and you know how to drive without abs, I think it is safer and more predictable to drive without abs. )
