compound or twins question
Old Feb 4, 2011 | 04:10 PM
truckwrench1's Avatar
Default compound or twins question
sorry maybe a stupid question but have been surfing thru old posts and am finding that some people are running the smaller turbo on top of the larger. why?. would you not want the smaller turbo to help spool the larger one or am i just missing somthing. you would still see boost of the smaller turbo and then the big one would lite. what am i missing. ie he35 under a ht3b. the 35 would help build that LARGE turbo would it not?
Old Feb 5, 2011 | 04:09 AM
KD93's Avatar
There wouldn't be any advantage to running a smaller, (HX-35 etc) turbo under a bigger one, (HT3B etc.) You are correct in thinking the small one will light the bigger one. Funnily enough, the small one is referred to as the secondary, and the larger one as the primary, even though the smaller one gets spooled up first. I never understood that, but whatever. I've never seen a twins set up plumbed the other way around.
Old Feb 5, 2011 | 07:47 AM
RAW's Avatar
RAW
Twins are 2 turbos the same, feeding the engine. In an inline engine, cylinders 1, 2 and 3 feed one turbo, and 4,5, and 6 feed the other. On V configured engines, on side feeds one turbo, and the other side the other turbo.
Having the big turbo feed the little turbo is the most efficient. Atmospheric pressure is roughly 14psi, at that is what is available to a single turbo inlet. If a turbo can make 35 PSI with atmospheric pressure, adding 14 psi to the inlet of the small turbo should double the output of the small turbo, in theory. Of course the limitations of the turbos control the over gains, so does the fueling.
Old Feb 5, 2011 | 10:49 PM
thanks guys getting a better of understanding
Old Feb 6, 2011 | 02:03 PM
Red_Rattler's Avatar
High Tech Redneck
Because the smaller spools easier which is why its first on the exh side but on the intake the air goes throught the larger first. So basically the lil guy is for lowspeed crusing boost and helps to get the big one moving air the the lil one is regulated on the exh side so it wont over speed and the big boy takes over from there. Clear as mud?
PA 24valve
Aug 31, 2015 06:08 AM
Josh_L
Apr 12, 2015 12:12 PM
97 stroker
Ford Powerstroke 08-10 6.4L
Feb 18, 2015 03:25 PM
countryboy040993
Dec 31, 2014 05:10 PM
CumminsCrazed
5.9L 24V Performance
Oct 27, 2014 09:02 PM
