take over jumpin
when i pull up to a stop sign and i give it a little pedal to take off fast it feels like the back of the truck is jumping or something is catching. Any ideas why this would happen
Automatic .
only does it when i go to give it a little more pedal. if i take off slow it doesnt do it
possibly a u joint in the driveline, set the wheel breaks then crawl under there and wiggle the driveline and check it out, should be able to see the u joints good enough for a visual inspection
check you joints no play in them. I took it for another run and it seems like when you get on it it tries to upshift then studders. I read something about a govenor pressure sensor and a govenor pressure solienoid
Do you have a fuel pressure gauge?
i do have fuel pressure gauge nothing unusual there. I think its in the tranny cus there are some vibrations there. it only has 50,000 on tranny. I said hell with it taking it back to Bowler . Gonna have them check it out. Thanks for help
