06' 6.0L CEL
Old Feb 4, 2011 | 06:51 AM
jethro66's Avatar
Default 06' 6.0L CEL
My CEL came on this morning (-7 degrees) but the truck is running normal. I fueled up at the same place as always and it was this cold yesterday morning. Should I be concerned?
Thanks!
Old Feb 4, 2011 | 08:04 AM
MUDSTROKIN''s Avatar
Did you put in any kind of fuel addititve with that fuel?
Old Feb 4, 2011 | 12:12 PM
jethro66's Avatar
No
Old Feb 4, 2011 | 12:20 PM
I'd say your fuel might have gelled up a little, With temps like that you should add some winter time Power Service Diesel Kleen. Just keep an eye on it and you should be fine as long as it doesn't get any worse
Old Feb 4, 2011 | 12:23 PM
jethro66's Avatar
I'll put some in today, thanks for all the help.
Old Feb 4, 2011 | 12:37 PM
No problem pal, report back if you have any other problems
Old Feb 4, 2011 | 02:50 PM
PowerstrokeConnection's Avatar
I would say never ignore a check engine light until you know the code. It could be on for a random issue that all it needs is cleared but also a more serious issue that can cause damage and big bucks. At least have the code pulled. My2cents
Old Feb 6, 2011 | 12:46 PM
Mdub707's Avatar
Yeah, what is the code? You could be running low fuel pressure with partially iced over fuel filters...
tbreddiesel
Thoroughbred Diesel
Jan 12, 2015 02:23 PM
Dec 10, 2014 08:10 AM
makuloco2000
Oct 27, 2014 10:40 PM
Stick_Welder
9
Oct 24, 2014 04:10 AM
Oct 13, 2014 08:10 AM
