ok next question dana 80 spline count
Old Feb 3, 2011 | 07:16 PM
kyle davis's Avatar
Default ok next question dana 80 spline count
is it the dana 80 that has 35 spline axles? i tried to search but it erased 80 out of the search since it was less than 3 letters..
Old Feb 3, 2011 | 07:47 PM
diesel pap's Avatar
Site Sponsor - Mighty Diesel
mine is 35 spline in my 97.
Old Feb 3, 2011 | 10:40 PM
kyle davis's Avatar
hmm i wonder if they changed any in those few years i replaced an axle shaft a few years back when i snapped the cap off the shaft but never did count them just went to a junker and he had one for a 2000 already
Old Feb 3, 2011 | 11:35 PM
01quadcab's Avatar
the 80's are all the same 94-02 that is if it's still stock. I know 37 spline is an upgrade unit for them
Old Feb 4, 2011 | 06:55 AM
rab475's Avatar
my experince is 35 on dodge and 37 on f450. I tried to swap a dodge rp and carrier in a ford it all works except axles.
Old Feb 5, 2011 | 12:12 AM
kyle davis's Avatar
ok then which is better and whats the difference?
Powertrax Lock Right Locker Dana Spicer 80 35 Spl 2710 [PT 2710] - $412.00 : JTs Parts & Accessories, Justdifferentials.com
or
Powertrax No-Slip Locker Dana 80 35 Spl 92-0470-3500 [PT 92-0470-3500] - $545.00 : JTs Parts & Accessories, Justdifferentials.com
not to educated with this whol suspension and locker stuff sorry guys
Old Feb 5, 2011 | 02:45 PM
ghild's Avatar
I have a 2000 dodge 3500 dually with a dana limitd slip rear end. When I back up it behaves as if it is slipping intermittently. What is the prognosis for failure & how soon. I do not have the special lubricant additive that is added along with the regular sunthetic gear lube. If it is trashed, then is it possible to changer it for a standard 3rd member, non-limited slip differential? I have seldom pulled any heavy weight behind.
Old Feb 5, 2011 | 04:05 PM
D-LUX's Avatar
powertrax makes decient parts but personally putting that much power through them isnt a good idea.. ive broke two of the lock rites in my dana 60 in the front of my 84 with only a mild bigblock and 37's....id say arb or detroit locker all the way
Old Feb 5, 2011 | 05:40 PM
kyle davis's Avatar
i just have stock 31s so not that much tire to turn and i only plan on makeing 500 -600 hp at the most (most)
Old Feb 5, 2011 | 05:48 PM
D-LUX's Avatar
more than likely it will hold just fine but im just givin you my .02 cents good luck with the install
