Timing pin cover
Old Feb 3, 2011 | 05:56 PM
kieron_kohlmann's Avatar
Default Timing pin cover
so my timing pin is no longer in the holder. any ideas on how to plug the hole that's left behind? i know you can replace the timing pin but if i can strip out the torx bit fasteners that hold it on, its not coming out easily. any ideas to plug it up?
The timing pin on the gear case, not the pump.
Last edited by kieron_kohlmann; Feb 3, 2011 at 05:56 PM. Reason: Automerged Doublepost
Old Feb 3, 2011 | 07:53 PM
MNGuns's Avatar
So where is it that you think the pin went to...? I have my timing case off at the moment, and if I recall correctly, the pin is pushing into the case from the iside..?
Old Feb 3, 2011 | 08:19 PM
its the timing pin on the engine that goes into the cam at #1TDC. I need to plug it.
Old Feb 4, 2011 | 09:14 AM
captain_stabbin's Avatar
you can get a new 1 for like 6 bucks
Old Feb 4, 2011 | 03:34 PM
ya but you cant easily get the old one off.
Old Feb 13, 2011 | 03:57 PM
hannacorona's Avatar
i'm going to have to replace my pin also. It didn't fall out,but it is damaged. do you have to remove the timing cover to replace the pin?
Old Feb 13, 2011 | 07:15 PM
Rodburner07's Avatar
No you dont remove the cover......thers a snap ring that holds the pin in, but is a bitch to see and get to.. i never put the snap ring back on, and nvr have lost a timing pin, it has an oring on it and as long as the oring is ther its a pretty tight fit and very hard to pull out ne ways
Old Feb 13, 2011 | 07:51 PM
Thats how i lost mine. I pulled the snap ring out. with the ring out, the pin fell out eventually.
Old Feb 14, 2011 | 06:22 PM
joshbaker's Avatar
You dont have to take anything apart to get to the timing pin. I litteraly just used mine to time the pump to 19.5* And yes it will come out but not without a little pulling force. It is a pain in the but to get to though. The pin is on the engine tucked inbetween the vacume pump and injection pump.
Old Dec 15, 2011 | 10:00 PM
4bt's Avatar
4bt
I hate to resurrect an old thread but I had the same problem today on my 93 D350. I attempted to lash my valves and found that the timing pin was frozen in the bore. After prying on the pin I was able to pop it from the bore and noticed that the o-ring was swollen up from age. I removed the o-ring and was able to find TDC without issue. Any suggestions on how to re-install the little locking ring with teeth....... to keep the pin from falling out?
thanks from a noob
dango
Jun 21, 2016 01:13 PM
quiksilver1j
Jul 30, 2015 12:41 PM
carid
Diesel Bombers Sponsors
Jul 16, 2015 05:11 AM
Stox5225
22
May 14, 2015 05:17 PM
SMatyac
Nov 15, 2014 07:35 PM
