Want a limited slip, need parts
Old Feb 3, 2011 | 04:34 PM
gump's Avatar
Default Want a limited slip, need parts
I'm sick and tired of the open diff in the rear end of my truck. It makes getting around town on ice covered streets a pain since I almost always have to use 4wd. So, I want to install a limited slip. I found a new one on Jegs for $840, but I can't find what bearings to use. Where can I find the right ones?
Also, if anyone knows if a different place to get a different carrier that isn't so expensive (or have an old one that is GOOD laying around) I'd like to know. Don't say junkyard though, I don't do that.
Old Feb 4, 2011 | 05:24 PM
gump's Avatar
OK how about I phrase it like this. I need differential carrier bearings. What's the part number and where do I get them?
Old Feb 5, 2011 | 09:59 AM
cfarley0210's Avatar
call up randys ring and pinion they should be able to get you set up with what you need but expect to pay for them they wont be cheap. if anyhing they can get you the part numbers and you can get them somewhere else. or you could probably pull your bearings off your other carrier and use those. you can find there # online
Old Feb 5, 2011 | 10:02 AM
dangerous1965's Avatar
Check out e-bay also!
Jul 21, 2015 07:50 AM
Feb 12, 2015 05:40 PM
carid
Towing and Hauling
Oct 27, 2014 10:46 AM
Sculpturesylvan
Oct 18, 2014 10:40 PM
Sculpturesylvan
Oct 18, 2014 10:19 PM
