Where did my power go?
Old Feb 3, 2011 | 03:50 PM
godblessmud's Avatar
Default Where did my power go?
Yesterday my 94 12v lost all power while sitting at a stop sign. I had to limp it the rest of the way to my buddies house and then all the way home again. I had filled up the day before at a new gas station because of their 20c off discount so my first thought was that **** in the tanks had clogged up my fuel filter. So i changed that and the problem actually seemed to get worse cause today I cant even drive it over 25mph without going downhill..
Symptoms:
NO smoke except on startup
No power
Fuel pedal is really hard to push
When I disengage the clucth and take the load off the motor idle drops to 2-300 then pops back up to only 500 rpms
It just flat out feels like its starving for fuel but I already changed the filter Im wondering if the fuel shutoff solenoid didnt get tripped somehow and how do I check that?
Any ideas?
Old Feb 3, 2011 | 07:01 PM
monster12valve's Avatar
suck tube could be clogged.... ip or lp may be bad. i would check fuel pressure at the ip first
Old Feb 3, 2011 | 09:19 PM
fury9's Avatar
maybe an inter cooler boot blew out
Old Feb 3, 2011 | 09:32 PM
So it is dark and raining tonight I cant see much but I did notice that the metal canister that bolts onto the AFC housing has broken out the bolt hole on the back side of the AFC. I beleive that canister is a fuel regulator of some kind but correct me if im wrong...
Old Feb 4, 2011 | 09:12 AM
captain_stabbin's Avatar
pics of this?
Old Feb 4, 2011 | 07:11 PM
lodal cummins's Avatar
that is your problem. you are getting no boost to your afc meaning no rack travel= not much fuel to your injectors!
Old Feb 8, 2011 | 03:46 AM
Okay guys I found the problem, it was the emergency fuel shutoff! Upon closer inspection it had ripped out the bolt holes on the AFC housing and fallen over and because it is a gravity fed system cut off almost all my fuel. A few helicoils and grinding a new bracket later she runs better than ever.
Old Feb 8, 2011 | 05:28 PM
blazier18's Avatar
fuel shut off rod may have came down mine did that and everytime i started it i had to get out and push up the rod and she was good till i turned it off
May 10, 2015 10:57 PM
explorer197143
Dec 28, 2014 01:14 PM
