i have 3 codes on my ecu
Old Feb 2, 2011 | 11:41 PM
red3022's Avatar
Default i have 3 codes on my ecu
my truck is giving codes 230 1689 and 216 the dealer i talked to today say its wiring but can the vp being bad cause the lift pump to throw a code also
Old Feb 3, 2011 | 07:24 AM
RAW's Avatar
RAW
https://www.dieselbombers.com/codes.php
Old Feb 3, 2011 | 07:37 AM
Whit's Avatar
Site Mascot
is it running good?
Old Feb 3, 2011 | 06:03 PM
red3022's Avatar
no it dont run very good white smoke and a mis and no power
Old Feb 3, 2011 | 07:29 PM
RAW's Avatar
RAW
P0230, lift pump electrical failure
P0216 Injection pump timing failure ( usually the electronics burning up)
Kind of sounds like your lift pump failed, failing your Injection pump. Sorry man.
Old Feb 3, 2011 | 07:33 PM
chad83181's Avatar
Yep I have to agree with above seen this on two of my buddies vehicles
Old Feb 4, 2011 | 10:28 PM
red3022's Avatar
that sucks thanks guys its going to the shop next week new vp lift pump and a pressure gauge hopfully its fixes it
Old Feb 4, 2011 | 10:29 PM
Dont put a oem lift pump on it and dont put the intank pump on it.
Old Feb 4, 2011 | 10:39 PM
red3022's Avatar
it has the in tank but as soon a i get the money to buy one im gonna go with probly a raptor been told thats a good pump
Old Feb 5, 2011 | 07:33 AM
RAW's Avatar
RAW
It is a good pump, but that in tank bugger is still going to cause you problems. The Raptor could have a hard time pulling fuel through the in tank pump, and running both pumps can cause excessive pressure. I did that once to get out of a bind. I had a block mounted pump, and a in tank pump, together they made 31 PSI at idle, at the injection pump.
If you feel you are capable to do the repairs yourself, you can save A LOT of money. Enough to buy a good lift pump, and a proper Draw Straw for your tank. There are a lot of good write ups and videos of how to change your injection pump.
