Marker lights 93 7.3L Turbo diesel
Old Feb 2, 2011 | 03:51 PM
davidT's Avatar
Default Marker lights 93 7.3L Turbo diesel
When I turn on my headlights everything works fine. As soon as I turn off my head lights my marker lights stay on. I have to diconnect the aux battery, and I hear a click in the relay then the lights stay off, I have replaced the relay and the switch in the cab. The battery doesn't hold a strong charge if it hasn't been started for a few days as well. I don't know what else to do or what I should replace to fix this problem. Any advice would be greatly appreciated.
Old Feb 2, 2011 | 04:10 PM
FordDZLMan9191's Avatar
Are you pushing the headlight switch in all the way? Since you replaced the in cab switch, its possible that the dash panel may not have been put back on right and it might be sticking out to where the switch won't go in all the way. Other than that, I'm not sure what to tell you...
Old Feb 3, 2011 | 07:25 AM
davidT's Avatar
Yeah the switch is all the way in I checked that before I put the dash back on just to make sure that the dash wasn't the problem, I also Ohms checked the new switch before i put it in. The relay was warm this morning like it had power going to it all night. I am going to look at some wiring diagrams for the junction box to see where the hot wire comes into play, but other than that I still don't know which direction to go.
Dye Guardian
Aug 1, 2015 01:28 PM
carid
Diesel Bombers Sponsors
Apr 15, 2015 07:29 AM
yjownzme
Apr 6, 2015 01:01 PM
MrMoose
Mar 15, 2015 06:05 PM
Oct 24, 2014 04:40 AM
