tire size?
Old Feb 1, 2011 | 09:26 PM
peters's Avatar
Default tire size?
im puting a 3" leveling kit on a 05 cummins with stock rims what size tires can i run with out rubing
Old Feb 2, 2011 | 12:59 PM
CreeperSleeper's Avatar
I am running 35's with my leveling kit and I rub just slightly at full lock. That being said, I will never buy 35's for my truck again. I am really noticing the lack of power going from a 265. I think I will compromise with a 305 or 285 next time.
Old Feb 2, 2011 | 01:37 PM
Farmboy 2.0's Avatar
315's will be almost 35 inch tires and like 12in wide or so
Old Feb 3, 2011 | 10:20 AM
W.F.O.!'s Avatar
Default Tire?
I'm running 35" Nitto Trail Grapplers w/ 2" leveln, only slight rub at full lock. I've had these tires on for 11,000 miles and they are barely showing any signs of wear, I will def. get them again. Quiter then MT/Rs and BFGs that Ive run before.
Old Feb 4, 2011 | 11:23 AM
1AMatt's Avatar
Site Sponsor - 1aauto
Yup, I believe 315/70 R17s are ABOUT a 35 x 12.5. You will definitely not have clearance issues. If you are using stock wheels you may rub on you lower control arm a little bit when you cut the wheel all the way.
salty4life
Aug 20, 2015 10:46 AM
B737 Capt
Jun 9, 2015 06:34 AM
dallasca
28
May 26, 2015 12:58 AM
LB7yooper
Chevy/GMC Duramax 01-04 LB7
Mar 23, 2015 11:33 AM
LikeTheFabric
Ford Powerstroke 2011-Up 6.7L
Mar 10, 2015 01:18 PM
