torque converter lock switch?
Old Jan 31, 2011 | 11:20 AM
arobertson's Avatar
Default torque converter lock switch?
ok so iv heard of just putting a switch in the truck for a lock up. how does it work wial your driving. iv seen how to do it online but what does it do for your truck?
Old Feb 1, 2011 | 09:17 AM
moparious maximus's Avatar
Normally your truck will lockup the converter in third and OD, but will unlock fairly quick with pedal movement, brakes, or just slowing down.
The switch make the truck want to stay locked all the time in 2nd-OD and will NOT downshift, sometimes if you go WOT the tranny will kickdown anyways but the converter stays locked.
It can get you some more fuel mileage in town but it dont do much for highway driving because its locked in anyways. I think its very handy for towing heavy stuff, it keeps the trans temps WAY lower, and lets you load the motor harder.
You just have to remember to turn it off before you slow down or the truck will buck pretty bad or do what I do, just shut the swich off when the truck would normally have the converter locked anyway (between 40-50mph) depending on the gearing, then you dont have to worry about forgeting when a red light jumps out at you.
Old Feb 1, 2011 | 09:46 AM
arobertson's Avatar
ok so how do you use it? can you come to a stop and lock it then take off and the tranny will shift up just fine? i have a very low rear end 3:53s
Old Feb 1, 2011 | 10:03 AM
I would not recommend torque converter locked shifts on a stock transmission.
Old Feb 1, 2011 | 10:35 AM
kingbrad89's Avatar
If you lock it from a stop and take off, it will shift very hard, and sooner than normal shifts keeping the rpm's low. It's actually convenient if you have a built trans because it holds the truck in the peak horsepower range during acceleration and can take some significant time off your 0-60 or 1/4 mile times. BUT, if you don't have a built trans with billet shafts it's really not a good idea as it shifts very hard and can easily shear a shaft. I love my switch and I recommend it, just be smart with it
Old Feb 1, 2011 | 03:33 PM
arobertson's Avatar
its not stock. shift kit. billets input output. 3 disc converter. high energy pads. and upgraded valve body. it shifts hard already
Old Feb 1, 2011 | 03:46 PM
kingbrad89's Avatar
You'd be ok in theory to throw one on. I'd do it
Old Feb 1, 2011 | 07:54 PM
RAW's Avatar
RAW
Not without some billet shafts, eh?
Old Feb 2, 2011 | 08:33 AM
arobertson's Avatar
thats what i wrote on the last thread. it has billets shafts
Old Feb 3, 2011 | 03:06 PM
Our built tranny has stock shafts and it seems to be holding up, granted we dont beat it EVERY day but I'm definently not afraid to work it hard.
That little switch makes it a bunch of fun to drive
