lift pump questions
Old Jan 31, 2011 | 09:41 AM
arobertson's Avatar
Default lift pump questions
ok so if i run a ppe or fass on my truck do i have to do bigger lines? it should flow the enough with stock lines right? and if i run a ppe do i just use the stock fuel filter canaster?
Old Jan 31, 2011 | 10:52 AM
GuyWithA24Valve's Avatar
I don't know about the PPEs but I have a Fass 150 on my truck. The kit comes with fuel lines and I ran mine into the stock fuel bowl just because it has a fuel heater in it.
Old Jan 31, 2011 | 11:15 AM
arobertson's Avatar
that works. i was thinking i should run bigger lines. i have 3/8ths stainless tubing that i was thinking of running
Old Jan 31, 2011 | 11:23 AM
vineyardm's Avatar
Bigger lines - good idea.
But - getting rid of Banjo Bolts - a great idea! Improves flow and reduces pressure drops!
Old Jan 31, 2011 | 11:36 AM
arobertson's Avatar
k how do you get rid of them? iv seen it but whats the name of the kit for it?
Old Jan 31, 2011 | 11:51 AM
vineyardm's Avatar
Depending on what you already have ...you might need the BIG LINE KIT (Geno's Garage) ....or just the Filter to VP44 pump line (also at Geno's Garage.)
Check here: Fuel System Accessories-Dodge Cummins Diesel Truck Accessories – Geno’s Garage
or directly from Vulcan:
Vulcan compound turbo components, AirDog Raptor Systems, FireBall injectors, DrawStraw™, Big Line Kits, VP silicone boot kits, gauge installation components, metric adapters & fittings, FA, Quadzilla, Edge,AirDog, DTT Trans, ISSPRO, HTT Turbo, AFE, V
Nice thing about this concept - the fitting that goes on the VP44 has a 1/8" port that you can put your fuel gage sensor on (you do have a fuel presssure gage??? I hope???) - and you will get the most reliable pressure measurement at the point it counts the most - at the VP44!
Old Jan 31, 2011 | 12:02 PM
arobertson's Avatar
my truck is coming out of the shop this weekend and im putting a gauge on it then. i havent had it to long and its been down for a yr. couldnt get it to start. tried injector pump lift pump ecm and alot more. it was a brokin power wire to the security module 1000 bucks later and it runs . fuel pressure gauge the day i get it back. thanks
so the big line kit gives you fuel line and power wire to a frame mounted pump and the banjo bolt convertion?
sorry got my answer. just had to read further.
Last edited by arobertson; Jan 31, 2011 at 12:02 PM. Reason: Automerged Doublepost
twinturbo12v
5.9L CR Performance
Nov 26, 2015 02:06 AM
landon025
Sep 8, 2015 09:21 PM
Renteria1217
Apr 16, 2015 11:38 PM
klein444
Feb 21, 2015 10:33 AM
moneypitk5
Feb 12, 2015 11:01 AM
