06 cummins missing probs
Old Jan 29, 2011 | 04:51 PM
ftoy's Avatar
Sad 06 cummins missing probs
Yesterday i finished my cross country trip to michigan. Yesterday i thought it was missing at idle but still running fine on freeway. Today i have a major miss. I changed the fuel filter. I drained the water sep. Still the same problem. Any ideas?
Old Jan 30, 2011 | 09:39 AM
dangerous1965's Avatar
injector time if your far from home your gonna have to find a diesel shop in the area or maybe a stealer! Any codes? Any smoke?
Old Jan 30, 2011 | 09:53 AM
CountryGirl91's Avatar
Mine would miss bad a few weeks ago and would white smoke bad at start up until I put it in gear a go. I'VE NEVER BEEN A BELIEVER IN FUEL ADDITIVES BUT, I used Stanadyne fuel additive (they make injectors too, I heard), and after I ran a tank with it, it hasn't missed or smoked at all ever since.
It's probably a temporary fix, but I can't buy injectors right now so I've been happy with the results.
Old Jan 30, 2011 | 11:14 AM
ftoy's Avatar
no smoke or stalling still gets the same mileage on the highway. it only has 67000 mi. maybe bad fuel. never had a prob in California. thanks for the advice
Old Jan 30, 2011 | 09:11 PM
still under warranty!?
Old Jan 31, 2011 | 05:04 PM
TeckJohn's Avatar
I have owned 7 Quad cab cummins Dodges 2003, 2 2005, 3 2006 and now a 2008 and they have been the best trucks I have ever owned. We hauled signs all over the 48 states. The main problem I had was loose injector tubes. they make you smoke, loose power, miss, stall, think you have bad injectors and a bad CP3 Pump and a bad lift pump. These lines are very easy to tighten if you are even just a little mechanically inclined. You have to hold the tube with one wrench and loosen the line with the other and then tighten the injector tube.
Old Feb 15, 2011 | 08:15 PM
lunk's Avatar
good to know
Old Feb 15, 2011 | 10:19 PM
fast_stang_88's Avatar
Try some good diesel cleaner, there are a few on the market. If that doensnt help in the next few tanks I would lean towards an injector or the tube.
Old Feb 28, 2011 | 10:12 AM
ftoy's Avatar
problem solved i had a bad #2 injector. was under warranty so i lucked out. thanks for the help
Shun70
Diesel Engine Conversions
Jun 1, 2026 05:02 AM
Sbboozer
Nov 16, 2014 05:52 PM
Oct 31, 2014 08:10 AM
Oct 24, 2014 04:40 AM
Omingnome
Oct 20, 2014 12:25 PM
