running problem with my IDI
Old Jan 29, 2011 | 03:09 PM
logan80's Avatar
Default running problem with my IDI
Im have a running problem with my IDI 6.9 Non turbo...The truck with idle rough and the truck will shack truck and then it will come out of it and idle smooth or you can give it fuel and it will come out of it...And when the truck sits over night or during the day when you start it it will run for 2 seconds and die and you can start it up again and it will stay running ..I put new glow plugs , glow plug really , The injector top caps ,o-rings ,lines kit ,fuel filter...If you have any ideas i would appreciate your input! Thanks
Old Jan 30, 2011 | 12:30 AM
stackboy6.9's Avatar
is the pump turned up
Old Jan 30, 2011 | 09:39 AM
DieselCrawler's Avatar
sounds like you are till having fuel bleeddown issues or air intrusion.
Old Jan 30, 2011 | 03:08 PM
logan80's Avatar
The pump has been turned up 1 FLAT but was doin it before it was turned up..The water separator has been bypassed from the person who owned the truck before me.. I put a new lift pump On the front side of the engine because it was leaking fuel..
Old Jan 31, 2011 | 09:21 PM
agent_123_2000's Avatar
i dont know that id be running it with no fuel filter for 1, and id be checking for an air leak somewhere.
Old Feb 1, 2011 | 06:59 PM
logan80's Avatar
I am running a fuel filter! I said the water separator was by-passed.
burndiesel
10
Feb 7, 2023 01:15 AM
wildhorsemfg
Show And Tell
Sep 20, 2015 11:26 AM
jeremy01995
Sep 14, 2015 06:34 PM
justingrunow
Jeep Liberty
Aug 19, 2015 02:53 AM
carid
Diesel Bombers Sponsors
Jan 12, 2015 04:32 AM
