engine washing
Old Jan 29, 2011 | 10:12 AM
dolla_hite's Avatar
Default engine washing
planning on washing my engine and compartment was wanting to know if theres anything that i shouldnt power wash or try not to get very wet?
Old Jan 29, 2011 | 10:25 AM
RAW's Avatar
RAW
I always use low pressure was on the engine. The alternator shouldn't get soaked, but I frequently pass over it a few times. Everything under the hood is pretty sealed, but enough force will open anything up. I suggest to start at a safe distance, and if there are a few ignorant spots, get a little closer.
Old Jan 29, 2011 | 10:29 AM
turbostang7's Avatar
STAY AWAY FROM THE PCM, if it gets hit with to hard of pressure or gets watter in it, your truck will not be happy! other than that i hit mine with the steam cleaner from time to time and never had a problem, also depends on where you are from, here in idaho it getts a little cold this time of year and if you wash it the throttle cable will freeze, haha i found out the hard way on that. i thought engine heat would be enough but you find out quick when you try to slow down and she wont
Old Jan 29, 2011 | 10:30 AM
dolla_hite's Avatar
so pretty much stay away from alternator. would putting a plastic bag over it be job just in case things get a lil crazy?
Old Jan 29, 2011 | 10:32 AM
yep plastic bag will do the trick!
Old Jan 29, 2011 | 01:25 PM
thebullet83's Avatar
and if you wash it while the truck is hot, don't splash to much to fast on the exhuast manifold. heat shock and cracking could happen.
burndiesel
10
Feb 7, 2023 01:15 AM
klein444
Jun 20, 2015 11:48 PM
hershwork
Mar 1, 2015 05:15 PM
metal_miner
Diesel Engine Conversions
Dec 23, 2014 11:40 PM
Oct 30, 2014 08:10 AM
