wtf!!!!!
Old Jan 29, 2011 | 01:12 AM
captain_stabbin's Avatar
Default wtf!!!!!
i have been having some problems in the past with my ip acting stupid. when you runn the outta it, it starts missing for a couple seconds then runs fine then missing again an wont idle, any help would be great truck has great fuel pressure, no plate. with 191'dv's and 4k springs
Old Jan 29, 2011 | 07:25 AM
94 12valve's Avatar
I had the same problem with mine, turned out to be a loose fitting. check your fitting on the inlet side and return side of the pump to make sure you have no air leaks.
Old Jan 29, 2011 | 04:31 PM
well i have already changed the pump out with another 1.
Old Jan 29, 2011 | 06:36 PM
94 12valve's Avatar
make any difference?
Old Jan 29, 2011 | 10:31 PM
yea truck runs fine, but doesn't fuel like the other pump, all my stuff from my other pump is in this one. power just aint there!
Old Jan 30, 2011 | 08:23 AM
94 12valve's Avatar
what pump did you swap in?
Old Feb 1, 2011 | 11:19 PM
175 same as old 1
Old Feb 1, 2011 | 11:43 PM
12vcummins96's Avatar
Old Feb 2, 2011 | 04:30 PM
12valvetater's Avatar
Return line plugged up?
Old Feb 3, 2011 | 05:29 AM
negative ghost rider
