fuel pin
Old Jan 28, 2011 | 04:37 PM
tedge's Avatar
Default fuel pin
Have a 1993 dodge with 97 turbo, larger injectors,3 inch exhaust, pump turn up,boost and exhaust temp gauge ,few other mods. Thinking about going with a stage 2 fuel pin, But dont want excessive black smoke, any input out there on how much smoke or how soon it may clear under wide open throttle, or no black smoke at all.. if i adjust star wheel inside pump. Also think i should go with a 3200 gov spring?? any input would be great . thanks
Old Jan 28, 2011 | 09:00 PM
kingbrad89's Avatar
Default fuel pin
Any time you add fuel and not more air you're gonna see more soot. There's really no way around that unless you're matching air with fuel exactly. Running compound turbos will help with the smoke because it'll introduce more air with faster spool, and more air at high rpm but that's really about it other than just saying keep your foot out of it. Good luck man!
Old Jan 30, 2011 | 01:23 PM
cummins bronco's Avatar
i have a denny T pin and the smoke is very controlable, although if you lug it and put the pedal to the floor it does smoke pretty good.
Old Feb 1, 2011 | 10:56 AM
KD93's Avatar
This will happen with a stock truck too.
Old Feb 1, 2011 | 11:12 AM
Levi Miller's Avatar
go with the spring and fuel pin most deff and with every thing i have done to my truck it smokes a little on the bottom end if i stomp on it butt virtualy none on the top at wot i like the no smoke butt then again if i turn my pump another turn or turn and a half i can smoke like a freight train and make it where you cant se the highway behind me and my egts stay in check good luck with it man
Old Feb 1, 2011 | 02:05 PM
901stgen's Avatar
x2 on that. You cant go wrong with the spring or the pin.
Old Feb 1, 2011 | 04:16 PM
kingbrad89's Avatar
Not to change the subject but hey KD3 i see you are without a truck! I have an 89 D250 12v that ill sell to the first buyer, $2500.
Old Feb 1, 2011 | 06:32 PM
901stgen's Avatar
Oh man! if i had the money i would ****** it up in a heartbeat. Whats wrong with it?
Old Feb 1, 2011 | 09:04 PM
kingbrad89's Avatar
Default fuel pin
Nothin it's got 12/11 inspection stickers. Ready to go
Old Feb 2, 2011 | 06:57 AM
KD93's Avatar
I appreciate the offer , but mine is in, shall we say, EXTENDED overhaul! As time and money allows. I should change that status, shouldn't I...
I don't know how it works on this site, but your post might be breaking a rule or two about posting wanted/for sale stuff in the general forum. Have you tried listing it there?
