2001 Sputter and stall ...no codes
Old Jan 28, 2011 | 07:45 AM
arrowman1's Avatar
Default 2001 Sputter and stall ...no codes
hey guys...new to the DB but hopin for some tips
My 01 started dying out after about 20 minutes ..driving or idling
Coughs sputters....then the RPMs run up to about 2200 on its own and then it just shuts down
Couple minutes with the key off and it fires right up but usually will only run for thirty seconds or so and then same thing happens.
Ive checked the complete fuel system,running two lift pumps w/pusher at the tank
Changed filters,cleaned all lines and connections,fuel press never drops
Ive checked all the connections...grounds...fuses...relays...cant find a prob anywhere
It must be something electrical or the VP but iVe never seen one act quite like this one
The crazy part is its not throwing any codes and no check engine light.
Old Jan 28, 2011 | 09:17 AM
GuyWithA24Valve's Avatar
Well first off welcome to Diesel Bombers!
I'm not sure what your problem would be, but have you ever checked or adjusted the APPS? Just an idea. How much fuel pressure do you have going to the VP?
Old Jan 28, 2011 | 09:24 AM
Default Re: 2001 Sputter and stall ...no codes
Sounds like VP44 or Apps
Old Jan 28, 2011 | 09:29 AM
biged681985's Avatar
so u have the intank pump? and a lift pump on the side of your block? if either pump is weak, it acts like a restriction. then that would be my guess where ur problems are coming from. your not supposed to run two lift pumps on these trucks. the reason for the rpm jumping after it stumbles is because it gets a good shot of fuel when its struggling.
Old Jan 28, 2011 | 09:41 AM
What's your fuel pressure?
Old Jan 28, 2011 | 11:23 AM
arrowman1's Avatar
Default fuel pressure
thanks for the replies
truck has a cummins pump on the block and aftermarket external at the tank
fuel pressure is approx 16 idle and 12-13 under load
this setup has been on for 4years and never had any problems
we did a flow test from the VP return and its approx. 1 gal a minute so should be plenty of fuel
ive got a full set of gauges and everything reads normal when it shuts down
a cpl months ago it stalled a cpl times and i replaced the cam sensor
when that happened it just shut off like you turned off the key
it did show a code then and ive had no more problems until now
im wondering if maybe the new sensor is crapping out and just not setting a code even though it should be
